shanYE west Posted August 29, 2011 Report Posted August 29, 2011 mine did the same thing. take your filters off and try to run without them. i just wasnt getting enough air. not a filter issue.. Quote
Tedder Posted August 29, 2011 Report Posted August 29, 2011 Does it fall off as soon as you dump the clutch or will it run out strong for a few bike lengths then quit? Quote
camatv Posted August 29, 2011 Report Posted August 29, 2011 are you launching it at 7500+rpm? outerwares dirty? to much gearing? too much tire?? if i was around it i could figure it out i bet BUT over the net typing is hard to do.. you should just bring it down here and we will skid off a smooth section on the sand bar.. Quote
camatv Posted August 29, 2011 Report Posted August 29, 2011 oh also whats teh squish test show? whats the BOGG sound like ( as i said hard to do over the net) can you bogg it so hard it dies?? ( wayy bad on shift forks) might even be a brake drag OR a bad output shaft bearing.. or some other bearing inside the motor shooting hell .. Quote
Rotax Raptor Posted August 29, 2011 Author Report Posted August 29, 2011 I can be on damp grass in the return area at the strip rolling along at idle speed,nail the throttle and it will bog. If I hold the throttle on, yes it would eventuality kill the motor. It's not a gearing issue. I've tried it with the filters off. Quote
coryv4 Posted August 29, 2011 Report Posted August 29, 2011 I can be on damp grass in the return area at the strip rolling along at idle speed,nail the throttle and it will bog. If I hold the throttle on, yes it would eventuality kill the motor. It's not a gearing issue. I've tried it with the filters off. bog or cutting out if its cuttin out it sounds like an elect problem i spent 5 month fucking with my banshee because my stator tested fine i replaced it as a last ditch effort and it ran great Quote
Rotax Raptor Posted August 29, 2011 Author Report Posted August 29, 2011 oh also whats teh squish test show? whats the BOGG sound like ( as i said hard to do over the net) can you bogg it so hard it dies?? ( wayy bad on shift forks) might even be a brake drag OR a bad output shaft bearing.. or some other bearing inside the motor shooting hell .. The squish is exactly what McCoy said it should be. You can take off from the trailer and it sounds great, kick it in neutral and rev it cleaning it out, put it in gear and nail it and it falls in its face. I may bring it to you cam. Quote
Tedder Posted August 30, 2011 Report Posted August 30, 2011 My wifes bike was doing exactly as your describing. It was a lean pilot curcuit. Quote
shanYE west Posted August 30, 2011 Report Posted August 30, 2011 My wifes bike was doing exactly as your describing. It was a lean pilot curcuit. he's got lectrons.. no pilots Quote
Rotax Raptor Posted August 30, 2011 Author Report Posted August 30, 2011 My wifes bike was doing exactly as your describing. It was a lean pilot curcuit. Tell me more.. I have 41.3 lectrons set up by Packard. I've thought its been a fuel/air issue but all of the carb changes and adjusting just hasn't produced any significant changes to the problem. Quote
camatv Posted August 30, 2011 Report Posted August 30, 2011 richen it up try that make is SOO rich its hard to clean out.. if not let me know and come on down./ could be something simple could be something retarded, might even be a internal engine failure of some sort.. if jetting dosent change it and electrical dosent change it you gotta start looking at less obvious things.. Quote
Rotax Raptor Posted August 30, 2011 Author Report Posted August 30, 2011 I've had the metering rods all the way up to 46.5 mm with the power jets wide open. I'm trying to get hold of Garret at GT Performance and take it to him on Thursday and get it in his dyno and work it out. If not, its going somewhere. I am at a loss and sick of fucking with it. I wish Andy wasn't so far away, but it may come down to it. I will have plenty of cold ones on hand at the hq ride for all those that have been helping. I do appreciate all of the input. Quote
4MiLLDraGSheE Posted August 30, 2011 Report Posted August 30, 2011 YES! Even though i dont drink i still want one! I just like to hold them and make me look cool... Quote
Rotax Raptor Posted August 30, 2011 Author Report Posted August 30, 2011 You can look cool all night then. We'll get it figured out and then its coming out of the drag bike and into my suspended frame for the trip. Quote
