patsbansh Posted May 21, 2011 Report Posted May 21, 2011 any and all info or knowledge on this. My bike is a 4 mil cub +12 swingarm from FAST just purchased slingshot lockup clutch, have override gears, outframe shearer pipes 39mm alky pwk's looking for experience with the dynatech 2 stage rev limiter and launch limiter programmable computer. i saw some nice launch clips and the guys said this is the way to go. any info about 1/4 mile and this bike would be greatly appreciated. i haven't run it yet with this set up just waiting on a couple more parts to arrive and still have lots of questions. Jeff from FAST has been extremely helpful in this process. Thanks Jeff Quote
NYUK Posted May 21, 2011 Report Posted May 21, 2011 pat, it`s john. private message, tedder, and slowerthanyou. 2 real fast guys with small motors. i am sure they can steer you in the right direction. Quote
SlowerThanYou Posted May 21, 2011 Report Posted May 21, 2011 pat, it`s john. private message, tedder, and slowerthanyou. 2 real fast guys with small motors. i am sure they can steer you in the right direction. Thanks NYUK for the kind words. My PM is disabled, I'm more than happy to steer you in the right direction in open forum. Quote
patsbansh Posted May 22, 2011 Author Report Posted May 22, 2011 Thanks NYUK for the kind words. My PM is disabled, I'm more than happy to steer you in the right direction in open forum. thanks guys any info you could give me would be great i'm new at the asphalt game but am hooked and am learning some expensive lessons anything you tell me about ignitions would be fantastic , i mesaged tedder and he told me what he was running for ignition and i think i might be going in the wrog direction with the dynatech for what i wanna do & i don't wanna learn the expensive way again. Thanks Quote
patsbansh Posted May 22, 2011 Author Report Posted May 22, 2011 Thanks NYUK for the kind words. My PM is disabled, I'm more than happy to steer you in the right direction in open forum. also i'm looking for best front rear sprocket ratio right now i have 17/37 with 20.5 american racers Quote
SlowerThanYou Posted May 22, 2011 Report Posted May 22, 2011 thanks guys any info you could give me would be great i'm new at the asphalt game but am hooked and am learning some expensive lessons anything you tell me about ignitions would be fantastic , i mesaged tedder and he told me what he was running for ignition and i think i might be going in the wrog direction with the dynatech for what i wanna do & i don't wanna learn the expensive way again. Thanks To each their own on the ignition and I'm good friends with Tedder. I run the Dyna ignition and it works great depending on what you are trying do. I'm deffinately not a fan of their customer service. Quote
SlowerThanYou Posted May 22, 2011 Report Posted May 22, 2011 also i'm looking for best front rear sprocket ratio right now i have 17/37 with 20.5 american racers The gearing may or may not be right. Depending on your primary gear ratio, over all weight & density altitude. To name a few things to consider. I would look at changing your rear tires. If I'm not mistaking that is a 10" wide tire. IMO that's too much tire for that combination. Quote
Tedder Posted May 22, 2011 Report Posted May 22, 2011 Hi Pat, Like I said in the pm I've only used Wilburns (currently own 5 of them) which I love but Dyna's will do the job also. SlowerThanYou can help with your Dyna questions. We've killed cell phone batteries more than once chattin' about racing. lol Quote
sleeper06 Posted May 22, 2011 Report Posted May 22, 2011 not to post hi-jack but its relative to the post,does that wilburn unit retard the timing at certain rpms so you can run certain big timing out the hole and bring it down as you go down the track Quote
SlowerThanYou Posted May 22, 2011 Report Posted May 22, 2011 not to post hi-jack but its relative to the post,does that wilburn unit retard the timing at certain rpms so you can run certain big timing out the hole and bring it down as you go down the track Simple answer, yes. Quote
patsbansh Posted May 23, 2011 Author Report Posted May 23, 2011 The gearing may or may not be right. Depending on your primary gear ratio, over all weight & density altitude. To name a few things to consider. I would look at changing your rear tires. If I'm not mistaking that is a 10" wide tire. IMO that's too much tire for that combination. On your dyna do you have a launch limiter and what are you using to set it off? I've heard of something on the clutch perch, but what? Also i will be running on alcohol do i tune the bike and then install the computer or do it all at once? Also i have an adjustable timing plate, will this interfere with the computer or do i just turn one or the other down? Hope this isn't too much at once, like i said i have a ton of questions. Thanks for your input Quote
sleeper06 Posted May 23, 2011 Report Posted May 23, 2011 On your dyna do you have a launch limiter and what are you using to set it off? I've heard of something on the clutch perch, but what? Also i will be running on alcohol do i tune the bike and then install the computer or do it all at once? Also i have an adjustable timing plate, will this interfere with the computer or do i just turn one or the other down? Hope this isn't too much at once, like i said i have a ton of questions. Thanks for your input why do you need thatb launch limiter,In my time working on streetbikes ,quads i have seen tons of dyna boxes fail but they work for some,if you need anything let me know Quote
SlowerThanYou Posted May 23, 2011 Report Posted May 23, 2011 On your dyna do you have a launch limiter and what are you using to set it off? I've heard of something on the clutch perch, but what? Also i will be running on alcohol do i tune the bike and then install the computer or do it all at once? Also i have an adjustable timing plate, will this interfere with the computer or do i just turn one or the other down? Hope this isn't too much at once, like i said i have a ton of questions. Thanks for your input We use a adjustable switched clutch lever. It can be bought from MPS or Pingle Racing. The non adjustable will work, but not as well as a dialed in adjustable. As for your second question. IMO you should start out on race gas, but to each their own. As for doing them all together, that's your choice. As for the adjustable timing plate, we leave ours at 0 degrees. Every once in a while we use it for a quick adjustment on the timing. Quote
SlowerThanYou Posted May 23, 2011 Report Posted May 23, 2011 why do you need thatb launch limiter,In my time working on streetbikes ,quads i have seen tons of dyna boxes fail but they work for some,if you need anything let me know I've been drag racing too many years and a launch limiter is key in many areas. Here's a couple of examples: clutch tuning & reaction time consistency. It can be a handy tool for other things also. Quote
sleeper06 Posted May 24, 2011 Report Posted May 24, 2011 I've been drag racing too many years and a launch limiter is key in many areas. Here's a couple of examples: clutch tuning & reaction time consistency. It can be a handy tool for other things also. thank you i have just been skeptical seeing so many bad but its worth a try so i can tune my clutch a lil better Quote
