thank you i have just been skeptical seeing so many bad but its worth a try so i can tune my clutch a lil better
I'm not a big fan of Dyna, but the same ignition has been on our quad since around 2000.
The gearing may or may not be right. Depending on your primary gear ratio, over all weight & density altitude. To name a few things to consider. I would look at changing your rear tires. If I'm not mistaking that is a 10" wide tire. IMO that's too much tire for that combination.
What do you recommend for tires with those gears? Also i believe i saw clips of some of your launches on youtube the AKA was similar if not the same. That was turnd me on to the dyna and started my research process. Thanks
We run a 20" diameter by 8" wide American Racer and that will work for a good majority of set-ups.
