coldsmoke Posted January 30, 2011 Report Posted January 30, 2011 I purchased a new 'shee with a +4 durablue axle on it. the guy told me that banshee wheels dont fit the back and thats all he knew. i figured someone had put honda hubs on it. i tried to swap my +4 banshee swinger to that quad and found that the new axle has different splines and a larger diameter in the center. It makes me think that the axle as well as the swingarm are from another brand? id like to use the axle/hubs because they fit the beadlocks that came with the bike so i guess im shopping for a +4 swingarm for a mystery machine with a larger diameter rear bearing. Any help you guys could lend is greatly appreciated! hint, it also came with a 2 piston rear caliper as my banshee brake only had one piston. Quote
hnb Posted January 30, 2011 Report Posted January 30, 2011 get any pics and mabye hub stud dimensions Quote
crash&burn Posted January 30, 2011 Report Posted January 30, 2011 Get some pics and dimensions and some on here can help you out Quote
bansheesandrider Posted January 30, 2011 Report Posted January 30, 2011 Is it a round housing carrier? Could be an oversize drag axle, like the one from JJ&A. You definetely need to get us some pictures. Quote
coldsmoke Posted January 30, 2011 Author Report Posted January 30, 2011 Swingarm pics http://i1181.photobucket.com/albums/x439/ax3883/012.jpg http://i1181.photobucket.com/albums/x439/ax3883/011.jpg http://i1181.photobucket.com/albums/x439/ax3883/010.jpg I have to retake the axle pics bc they were blurry. they seem to be set up the same, except the carrier has a larger internal diamter to fit the thicker axle. The hubs were very close to 4 1/2" on center when i eyed them up with the tire still on. the brake rotor was a smallier diameter than the stock banshee... about the same size as the rear sprocket. A larger diameter axle would make sense. Are the larger diameter carriers common? Quote
n2otoofast4u Posted January 31, 2011 Report Posted January 31, 2011 Swingarm pics http://i1181.photobucket.com/albums/x439/ax3883/012.jpg http://i1181.photobucket.com/albums/x439/ax3883/011.jpg http://i1181.photobucket.com/albums/x439/ax3883/010.jpg I have to retake the axle pics bc they were blurry. they seem to be set up the same, except the carrier has a larger internal diamter to fit the thicker axle. The hubs were very close to 4 1/2" on center when i eyed them up with the tire still on. the brake rotor was a smallier diameter than the stock banshee... about the same size as the rear sprocket. A larger diameter axle would make sense. Are the larger diameter carriers common? Its gonna measure 40mm OD on the axle and the hub setup is gonna be Honda.. How many holes are in the sprocket hub? Quote
coldsmoke Posted January 31, 2011 Author Report Posted January 31, 2011 Its gonna measure 40mm OD on the axle and the hub setup is gonna be Honda.. How many holes are in the sprocket hub? 4 holes. its an aftermarket billet hub. Quote
coldsmoke Posted January 31, 2011 Author Report Posted January 31, 2011 Nice... Its a 250R axle. A 250 carrier will fit in my swingarm for the swap right? Quote
camatv Posted January 31, 2011 Report Posted January 31, 2011 250r rear end. probably has 250r brake caliper OR some home brew stuff swinger KINDA looks like a lsr but the welds and rear carrier fitment is deff not their high quality. the 250r and banshee carrer have about a 1/8 differnce in the mount location ( if i rember right) most time its not bad it might eat sprokets a lil bit. i have one of these 250r rear ends. the r axle is much bigger but heavy. i DO like that the R has a cooler rear brake mount, axle nut on them looks not as clutter'd up like the banshee double nut stuff. Quote
coldsmoke Posted February 2, 2011 Author Report Posted February 2, 2011 250r rear end. probably has 250r brake caliper OR some home brew stuff swinger KINDA looks like a lsr but the welds and rear carrier fitment is deff not their high quality. the 250r and banshee carrer have about a 1/8 differnce in the mount location ( if i rember right) most time its not bad it might eat sprokets a lil bit. i have one of these 250r rear ends. the r axle is much bigger but heavy. i DO like that the R has a cooler rear brake mount, axle nut on them looks not as clutter'd up like the banshee double nut stuff. So are the 250R and Banshee Carriers the same O.D? A 400ex should bolt into my swinger to allow me to use this axle if im doing my research right. Quote
252wheelieking Posted February 3, 2011 Report Posted February 3, 2011 Swingarm pics http://i1181.photobucket.com/albums/x439/ax3883/012.jpg http://i1181.photobucket.com/albums/x439/ax3883/011.jpg http://i1181.photobucket.com/albums/x439/ax3883/010.jpg I have to retake the axle pics bc they were blurry. they seem to be set up the same, except the carrier has a larger internal diamter to fit the thicker axle. The hubs were very close to 4 1/2" on center when i eyed them up with the tire still on. the brake rotor was a smallier diameter than the stock banshee... about the same size as the rear sprocket. A larger diameter axle would make sense. Are the larger diameter carriers common? What length is that round house swinger on the left in pic 2? Interested in selling it? Quote
coldsmoke Posted February 4, 2011 Author Report Posted February 4, 2011 Its a +4.... But no. i plan to use it on my build. Anyone hear of someone using a honda carrier im a yama swinger? I really hope its possible because i have a new 400ex carrier on the way!.... Im beginning to think that my swinger wont clamp down small enough to hold the carrier.... anyone looking for a brand new billet honda carrier? haha Quote
camatv Posted February 5, 2011 Report Posted February 5, 2011 the carriers i BELIEVE are differnt sizes but i think most have gone to a same size carrier BUT long time ago they used diff carriers in diff swingarms.. you should measure everything and then call somone like JJ+A OR LSR that builds multiple swingarm, carrier combo's Quote
tedd1 Posted February 5, 2011 Report Posted February 5, 2011 Honda, Yamaha (Banshee,660, and older YFZ 450s) carriers are 87mm. Late model YFZs and Suzuki 450s, Yam 700s are 90mm carriers. CanAm, KTM, Polaris, DS are 95mm. I believe the YFZs went to the 90mm about '05 or '06? Most of the 87mm carriers accept 35mm axles. Obviously, they can be had for 40mm axles. The 90mm and 95mm carriers usually run 40mm axles. Look >HERE< Quote
252wheelieking Posted February 5, 2011 Report Posted February 5, 2011 Its a +4.... But no. i plan to use it on my build. What's the length on the white swinger? Quote
