2 Stroke Screamer Posted November 7, 2010 Report Share Posted November 7, 2010 I've been reading through a few threads about adjustable timing plates and pretty much have the install down BUT!!!!!! here comes the silly question HOW DO YOU ACTUALLY TIME IT . the timing plate install that's pinned to the repairs and mods forum says to use the crack or split in the case as ur timing line can some one clarify this or post a couple of pic's just to clear up my confusion here thanks. Quote Link to comment Share on other sites More sharing options...
tedd1 Posted November 7, 2010 Report Share Posted November 7, 2010 You will see when you get in there. It is where the case halves come together. Quote Link to comment Share on other sites More sharing options...
power Posted November 7, 2010 Report Share Posted November 7, 2010 Does it work to adjust the stock timing plate? i got to ask i have no idea lol. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 7, 2010 Report Share Posted November 7, 2010 Does it work to adjust the stock timing plate? i got to ask i have no idea lol. you can modify a stock plate to adjust to +5.5 degrees...... Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted November 7, 2010 Report Share Posted November 7, 2010 I've been reading through a few threads about adjustable timing plates and pretty much have the install down BUT!!!!!! here comes the silly question HOW DO YOU ACTUALLY TIME IT . the timing plate install that's pinned to the repairs and mods forum says to use the crack or split in the case as ur timing line can some one clarify this or post a couple of pic's just to clear up my confusion here thanks. theres a top and a bottom case half. to adjust or set your timing plate, line a number up where the case halves meet. basically, if you look at the center of the stator/timing plate and look to the right untill you see the cases there will be a line (this is where the case halves meet) if the line is lined up with 0 then your timing will be at 0. more then likely you will want the case half line to line up with +4, which would obviously set your timing to +4. click the link vvv http://www.dunereview.com/Banshee%20Lighting%20Upgrade/TimingAdvanceDetail.jpg Quote Link to comment Share on other sites More sharing options...
2 Stroke Screamer Posted November 8, 2010 Author Report Share Posted November 8, 2010 theres a top and a bottom case half. to adjust or set your timing plate, line a number up where the case halves meet. basically, if you look at the center of the stator/timing plate and look to the right untill you see the cases there will be a line (this is where the case halves meet) if the line is lined up with 0 then your timing will be at 0. more then likely you will want the case half line to line up with +4, which would obviously set your timing to +4. click the link vvv http://www.dunereview.com/Banshee%20Lighting%20Upgrade/TimingAdvanceDetail.jpg Awesome thats exactly the info I was after you cant get any clearer than that. Was that your bike and if so what breed of timing plate was that one or could you recomend one. Thanks for that Quote Link to comment Share on other sites More sharing options...
06specialedition Posted November 8, 2010 Report Share Posted November 8, 2010 Awesome thats exactly the info I was after you cant get any clearer than that. Was that your bike and if so what breed of timing plate was that one or could you recomend one. Thanks for that I've used the Ricky Stator timing plate on all my bikes and never had an issue. Heres a link: http://www.rickystator.com/catalog/product_info.php?products_id=131 Quote Link to comment Share on other sites More sharing options...
4MiLLDraGSheE Posted November 11, 2010 Report Share Posted November 11, 2010 I just use pro design billet and works fine, put what degree u want lined.up with the case crack. Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted November 11, 2010 Report Share Posted November 11, 2010 Awesome thats exactly the info I was after you cant get any clearer than that. Was that your bike and if so what breed of timing plate was that one or could you recomend one. Thanks for that glad i could help! it's not my bike, but it does look to be a ricky stator timing plate. i've used both a rickystator timing plate and an rmstator timing plate and have had no problems with either. Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted November 11, 2010 Report Share Posted November 11, 2010 I recommend the chariot. They are nice pieces. A lot of guys run the ricky stator plate. They are cast like the stock one so....... I bought a chariot one from the site sponser off of ebay. It is billet and looks pretty but serves the same purpose as the RS one. You choose. The billet ones are more durable but that doesn't seem to be an issue with timing plates. Quote Link to comment Share on other sites More sharing options...
