kpennepacker Posted October 19, 2010 Report Posted October 19, 2010 I had my banshee out this weekend and as long as I half throttle it, it ran strong but when I cranked into it full throttle it would start sputtering. I have a Nology coil setup and 34mm flatside carbs. I am running the stock petcock with a Tee in it and 3/8 fuel line. I just ordered a dual pingle since it seems to be the problem. The bike power bands strong but seems to starve for fuel. I have the ground for the nology system right to the head. Is there anything else that would cause that. Quote
EvilBanshee Posted October 19, 2010 Report Posted October 19, 2010 does it spitter and stutter or like fall on its face when it starts to get wound out?? I would say your rich. but if it falls on its face your starving for fuel. Quote
kpennepacker Posted October 19, 2010 Author Report Posted October 19, 2010 does it spitter and stutter or like fall on its face when it starts to get wound out?? I would say your rich. but if it falls on its face your starving for fuel. It falls on its face. I'll try the new petcock and let you guys know if that helps Quote
GrMeyer Posted October 19, 2010 Report Posted October 19, 2010 Did you try going up on the main jet to see if it got worse or better? Quote
rdzbangshee Posted October 20, 2010 Report Posted October 20, 2010 i had to try a 150 t0 a 200 jet kit tell i ended up with a 180 jet a 185 was a tad rich on top little burble wot engine gets tight with a 170. Quote
kpennepacker Posted October 20, 2010 Author Report Posted October 20, 2010 Does any one know where I can get jets for the Mikuni flat sides or what jets fit these. Quote
06specialedition Posted October 20, 2010 Report Posted October 20, 2010 Does any one know where I can get jets for the Mikuni flat sides or what jets fit these. Hit up a site sponsor Quote
AKheathen Posted October 21, 2010 Report Posted October 21, 2010 if it's sputtering and breaking up when you stab the throttle wot, then it's rich...rich enough and it will even fall on it's face......if it just winds up or gets kinda quiet and seems to fall flat, until you back out of it, then it's lean.... Quote
kpennepacker Posted October 21, 2010 Author Report Posted October 21, 2010 Ok. I have CPI pipes v-force 3reeds. I have charriot intake with built in cross over. I am running an .08 over bore wiesco forged pistons and a Mod quad head an 21cc domes. A dune port Uni pod filters with the 34mm flatside. I am running the Nology ignition and plugs that came with it. I search the forum and tried to find what guy are running to get me in the ball part. Right now I have 190 main in each carb. I am around 500' in elevation. According to the digital tool kit I should be around a 380 and 37 on the pilot. Now the problem is out of the hole half throtttle it is shot of of the cannon. even through the gears. It power bands hard and pulls hard. As soon as you open the throttle all the way it falls flat. A slight sneeze then flat. I let back to half throttle and its back to pulling hard. I pulled plugs and they still look like new. I was looking to see if it was rich or lean. Quote
AKheathen Posted October 22, 2010 Report Posted October 22, 2010 Ok. I have CPI pipes v-force 3reeds. I have charriot intake with built in cross over. I am running an .08 over bore wiesco forged pistons and a Mod quad head an 21cc domes. A dune port Uni pod filters with the 34mm flatside. I am running the Nology ignition and plugs that came with it. I search the forum and tried to find what guy are running to get me in the ball part. Right now I have 190 main in each carb. I am around 500' in elevation. According to the digital tool kit I should be around a 380 and 37 on the pilot. Now the problem is out of the hole half throtttle it is shot of of the cannon. even through the gears. It power bands hard and pulls hard. As soon as you open the throttle all the way it falls flat. A slight sneeze then flat. I let back to half throttle and its back to pulling hard. I pulled plugs and they still look like new. I was looking to see if it was rich or lean. lean mains Quote
kpennepacker Posted October 22, 2010 Author Report Posted October 22, 2010 Are you saying to go down on the jets or to go up. I'm not used to the one line phrases. Quote
gotta_goatsfast Posted October 22, 2010 Report Posted October 22, 2010 I bet you're runnin your bike way lean. I'd jump up considerably on your jet size and work your way down before you cause some serious damage. Quote
AKheathen Posted October 23, 2010 Report Posted October 23, 2010 up, waaayyyy up..... don't listen to the jets-r-us reference..... 380 sounds about right...... Quote
kpennepacker Posted October 24, 2010 Author Report Posted October 24, 2010 Well I went to the cucle shop and got some what lucky. They had a pair of 400 mains so I got them and some other from like 320 and down. I had 35s in for pilots whick I left alone sine it seemed to run very well down low may have to adjust later on. I move the needle clip to the 4th notch up 1 from orignle. I put the air scews one turn out for a base line and put the dual petcock on and new fuel lines. SO I will try it tomorrow, and let you guys know. Thanks for all the help. Quote
bounty banshee Posted October 24, 2010 Report Posted October 24, 2010 I had my banshee out this weekend and as long as I half throttle it, it ran strong but when I cranked into it full throttle it would start sputtering. I have a Nology coil setup and 34mm flatside carbs. I am running the stock petcock with a Tee in it and 3/8 fuel line. I just ordered a dual pingle since it seems to be the problem. The bike power bands strong but seems to starve for fuel. I have the ground for the nology system right to the head. Is there anything else that would cause that. my banshee is doing the same thing let me know what it takes mineis messed up Quote
