juiceboxxx26 Posted September 10, 2010 Report Posted September 10, 2010 Hey guys my banshee is leaking oil from the exhaust where it connects to the jugs from both sides... one side more than the other, why is it leaking from the exhaust?? i cant really figuere it out, let me know what i gotta do to stop this and where it is coming from? Quote
cain Posted September 10, 2010 Report Posted September 10, 2010 Hey guys my banshee is leaking oil from the exhaust where it connects to the jugs from both sides... one side more than the other, why is it leaking from the exhaust?? i cant really figuere it out, let me know what i gotta do to stop this and where it is coming from? It's unburned two cycle it's normal try getting your pipes to fit tighter or replacing the little rubber gasket in your pipes Quote
pondtunes Posted September 10, 2010 Report Posted September 10, 2010 X2 on replacing the exhaust o-rings they're pretty cheap. Both cylinders firing all the time? if not the oil/gas could be building up causing more of it to be visible than normal, if you've got a misfire/random misfire it can even come all the way out the pipes depending on how old your silencer packing is. Quote
Fullthrottle02 Posted September 10, 2010 Report Posted September 10, 2010 I run 2 o-rings on each side. One goes in the groove of the pipe like usual and the other goes on the cylinder before the pipe. Quote
Jtw Posted September 11, 2010 Report Posted September 11, 2010 dont wanna worry u but, that happened to me as well. my crank seals were shot and needed to be replace. Quote
