No Limit Powersports Posted August 26, 2010 Report Posted August 26, 2010 Ok guys got the new serval cat running! I must say it is an absolute hoot to ride. The thing feels like the best stock cylinder dune port that we have done but pulls like a cub on top! This was a very conservative setup and we are going to try a few others very soon. Setup was like this As casted serval cat 68x58 22cc domes pump fuel (91 oct) +4 on the plate 34 pj's cgl needle 158 main. K&N Pods Cpi sb inframes The needle wasnt quite right it was lean off idle on the dyno but wasnt bad. I should be able to get more down low with more tuning or different carbs i really dont like pj's very well Overall the thing has awesome "usable power" and is a home run for CP! Great job Calvin serval1.pdf Quote
Nutwood 472 Posted August 26, 2010 Report Posted August 26, 2010 Ok guys got the new serval cat running! I must say it is an absolute hoot to ride. The thing feels like the best stock cylinder dune port that we have done but pulls like a cub on top! This was a very conservative setup and we are going to try a few others very soon. Setup was like this As casted serval cat 68x58 22cc domes pump fuel (91 oct) +4 on the plate 34 pj's cgl needle 158 main. K&N Pods Cpi sb inframes The needle wasnt quite right it was lean off idle on the dyno but wasnt bad. I should be able to get more down low with more tuning or different carbs i really dont like pj's very well Overall the thing has awesome "usable power" and is a home run for CP! Great job Calvin serval1.pdf how many hp Andy? cant down file on mini lap top Quote
crazycanuck Posted August 26, 2010 Report Posted August 26, 2010 Nice Numbers!!!, This might be a stupid question but do they look the same as Cub Cylinders?? Quote
vulvafan537240 Posted August 26, 2010 Report Posted August 26, 2010 those aint bad numbers at all for pump gas Quote
dirtydownunder Posted August 26, 2010 Report Posted August 26, 2010 awesome, i reckon these servals were made just for me thanx calvin !. good work andy !. Quote
No Limit Powersports Posted August 26, 2010 Author Report Posted August 26, 2010 They are identical to a cub exterior. Beyond the dyno sheet i got to ride the bike around for a little while before we strapped it down and it was a hoot to ride. Tons of usable power. You could lug it into a corner and power right out of it without touching the clutch. Its going to be a really fun duner/trail motor. I think with a little different dome/carb/pipe setup we could see more down low power than any oem cylinder can make and still pull on top! Quote
jbooker82 Posted August 26, 2010 Report Posted August 26, 2010 A dyno sheet with PWK 28's and Pro Circuit pipes would be intresting to see too. (same dyno of course) That is supose to be the hot set up for about the best bottom end and still being able to rev out on the top end. It would be cool to see the extreem opposite of what this cylinder can do. If you ever build one of these keep us up to date. josh Quote
No Limit Powersports Posted August 26, 2010 Author Report Posted August 26, 2010 28 pwks I have my pipe selection is kinda limited. I think I might be able to pull off some t5's off of another bike which will be very comparable to the PC fmf and others. Quote
hercalmighty Posted August 26, 2010 Report Posted August 26, 2010 Hey Andy, what is the difference between these and cubs? How do the porting maps compare? Any word on pricing yet? Quote
No Limit Powersports Posted August 26, 2010 Author Report Posted August 26, 2010 The serval cat is as cast dune port. Basically it is a very low port timing cub. If i remember Calvin told me that the exhaust was like 188*. It is identical to a cub on the outside just the port timings are low. Another thing that is great about it is if you decide later "hey i want to drag now" this little motor can do it and it can be ported just like a cub. They should be going on sale very soon Calvin was waiting for me to get some preliminary testing done to make sure he was where he wanted to be and i think he is! The target price is lower than a cub but thats if he can get the price where he wants it. Quote
dajogejr Posted August 26, 2010 Report Posted August 26, 2010 Hey Andy, what is the difference between these and cubs? How do the porting maps compare? Any word on pricing yet? These cylinders have lower, less aggressive port timings than a cub, hence the more usable power in lower RPMs...but can breathe well enough to rev out and make good power. I think stock carb to 33PWK with T5, CPI and probably Pro Circuit pipes would be a good test. Andy, I'd bet someone with Pro Circuits would be happy to let you borrow a set if you compensated them for shipping and/or a set of serval cylinders when you're ready to sell them.... Quote
