stroking Posted June 24, 2010 Report Share Posted June 24, 2010 (edited) i have the 4mil and 10mil cylinder here that im working on,and it seems that they use the same cylinder for all 3 cranks,10mil one being alittle taller but all ports and tranfers are the same,and that doesnt seem like the right thing to do to me. well i'll be porting the 10 and the 4mil this week and though id post what i find while doing so. ive started on one here Edited June 24, 2010 by stroking Quote Link to comment Share on other sites More sharing options...
stroking Posted June 30, 2010 Author Report Share Posted June 30, 2010 here are some pictures of the vito 4mil/stock stroke cylinders im almost done with one of them Quote Link to comment Share on other sites More sharing options...
stroking Posted June 30, 2010 Author Report Share Posted June 30, 2010 this is how the piston sits in the cylinder with a .060 base gasket i'm going to be using a stock base gasket and make some changes up top. Quote Link to comment Share on other sites More sharing options...
Titan up Posted June 30, 2010 Report Share Posted June 30, 2010 I didn't know the main exhaust was that close to the aux exhaust ports on those cyl's. Don't think that would be too healthy on the rings?? Quote Link to comment Share on other sites More sharing options...
drap660 Posted July 2, 2010 Report Share Posted July 2, 2010 Any updates? Quote Link to comment Share on other sites More sharing options...
stroking Posted July 3, 2010 Author Report Share Posted July 3, 2010 Any updates? its running like a monkey with 20 bumble bees stinging him on is azz!!! it made a really good increase in power from what i can feel. oh and how can you tell if the powerjets are open to much ? the plugs look new/wet with no burn spots on them Quote Link to comment Share on other sites More sharing options...
mike454 Posted July 4, 2010 Report Share Posted July 4, 2010 have you had any problems with the head studs trying to pull out an the porting looks good on those cylinders Quote Link to comment Share on other sites More sharing options...
stroking Posted July 7, 2010 Author Report Share Posted July 7, 2010 Ok im doing the (10mm) cylinder tranfers windows,look at where the piston stops at BDC. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted July 8, 2010 Report Share Posted July 8, 2010 What did each crank degree out to on each before you started cutting? Everyone says the 4 mil is way too high. It would be better to see the ports lower and need spaced up rather than down so far. I really wonder what the 10mil degrees out to with the ports that high. Before I cut anything I'd degree it out or bring it down and port from there. FYI many people are having the nikasil come off on these cyls. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 8, 2010 Report Share Posted July 8, 2010 That exhaust port is HUGE...what % of the cylinder width is that exhaust port? Looks like a piston eater to me too... Quote Link to comment Share on other sites More sharing options...
trx4502shee Posted July 8, 2010 Report Share Posted July 8, 2010 This is Todd I'm going to bring that bottom half today we put the crank in last night. Quote Link to comment Share on other sites More sharing options...
stroking Posted July 9, 2010 Author Report Share Posted July 9, 2010 That exhaust port is HUGE...what % of the cylinder width is that exhaust port? Looks like a piston eater to me too... thats how vito makes them Quote Link to comment Share on other sites More sharing options...
camatv Posted July 12, 2010 Report Share Posted July 12, 2010 looks to be about a 75-78% width exhaust but shape plays important on piston wear. the larger bore these are at should be able to handle 78% .. i run 75% 350's all the time BUT usually you can keep a lower % exhaust with the extra exhaust ports. keep them alive longer if needed .. if they are peeling that makes a great chance to send them in for welding and replate/ for report through millenium! who's plating them now? wish i could get a handle on a set of the 10's i could degree them out for you. cylinders could use some more work from those pics but you might be limited on what you can do. how were the old 10's stock cylinder motors set up from 10 years ago or so? i believe'd they had a spacer on top and droped the piston down farter like that. but i've never seen a set in my hand or had the chance to play with an old 10 mill stocker. Quote Link to comment Share on other sites More sharing options...
camatv Posted July 12, 2010 Report Share Posted July 12, 2010 wow i just noticed the sub exhaust ports need a lot of work they wren't even similar in shape size from the pics i can see not sure if its the way the pics were taken? whoo. Quote Link to comment Share on other sites More sharing options...
