mike454
    4 mill crank big bore sleeves 35mm carbs nitrous programable cdi box an dyna tech coil
mike454's Achievements
  1. Looking for a drag harness for banshee and stock cdi for 97 up thanks michael
  2. Have any pictures of carbs
  3. The motor is spittibg an popping out exhaust like it's goin lean but i have 118 main an dumps in 38mm mikunis an before this started with these dumps in it it would load up quick but now it's not
  4. How much psi are yall shooting in the motor when doing leak down i did 8psi an didnt get any leaks
  5. Ya same numbers on new pistons as old ones 20 thou base an same domes has stock cdi an switched it out with dyna see if it would make difference
  6. Its spitting out of both Cylinders tried diff plugs wires caps diff fuel put big dumps in the carbs opened power jets all way open its not smoking like it should when you have it running no restrictions in the pipes ones im using are diff from ones i had on it when broke ring motor just went lazy when i lost that one cylinder an piston was all still there when tore it down
  7. Pistons are in rite ring gap is 19thou compression before ring broke was 210 now left side is 180 an right is 160 new pistons an rings did leak down didnt find anything pickup is set at a business card thickness why am i getting feedback off my other cylinder when i block opposite side off?
  8. Added more fuel to it to the point were i know it was way fat an still didnt help u can block off right carb an left side goes to smoking an running like it should an vice versa im needing help any an all will be appreciated thanks
  9. Hey everyone i have a 4mill on alky thats giving me hell we had ring break couple months ago an it scared left cylinder so i sent cylinder to millinium got it back an now compression is way off from where it was an its also acting like its going lean spits out both pipes ive afde
  10. mike454
    reed help
    I got a 4mill cub on alky an it keeps eating reeds any idea why it has banshee boyz cages with carbon fiber reeds
  11. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  12. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  13. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  14. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
