mike454
Everything posted by mike454
  1. Looking for a drag harness for banshee and stock cdi for 97 up thanks michael
  2. Have any pictures of carbs
  3. The motor is spittibg an popping out exhaust like it's goin lean but i have 118 main an dumps in 38mm mikunis an before this started with these dumps in it it would load up quick but now it's not
  4. How much psi are yall shooting in the motor when doing leak down i did 8psi an didnt get any leaks
  5. Ya same numbers on new pistons as old ones 20 thou base an same domes has stock cdi an switched it out with dyna see if it would make difference
  6. Its spitting out of both Cylinders tried diff plugs wires caps diff fuel put big dumps in the carbs opened power jets all way open its not smoking like it should when you have it running no restrictions in the pipes ones im using are diff from ones i had on it when broke ring motor just went lazy when i lost that one cylinder an piston was all still there when tore it down
  7. Pistons are in rite ring gap is 19thou compression before ring broke was 210 now left side is 180 an right is 160 new pistons an rings did leak down didnt find anything pickup is set at a business card thickness why am i getting feedback off my other cylinder when i block opposite side off?
  8. Added more fuel to it to the point were i know it was way fat an still didnt help u can block off right carb an left side goes to smoking an running like it should an vice versa im needing help any an all will be appreciated thanks
  9. Hey everyone i have a 4mill on alky thats giving me hell we had ring break couple months ago an it scared left cylinder so i sent cylinder to millinium got it back an now compression is way off from where it was an its also acting like its going lean spits out both pipes ive afde
  10. mike454
    reed help
    I got a 4mill cub on alky an it keeps eating reeds any idea why it has banshee boyz cages with carbon fiber reeds
  11. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  12. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  13. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  14. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  15. cant wait until k&t performance gets done with Cylinders and portworks to get done with trans
  16. mike454
    cut trans
    Thanks yall would it be better to get a non dunner or a dunner its gonna be used for race only
  17. mike454
    cut trans
    Hey guys i have a 4 mill Banshee on alky were would be a good place to get a good 2-5 ovrride for samd drag thanks michael
  18. hey everyone i got a few banshee parts to get rid of have a set of 38mm mikuni alky carbs with filters 375 also have a set of 35mm d slide mikunis on gas with filters 225 also have a set of ten paddle 72ro also have a bunch of other parts for banshee if anyone interested just contact me 918 429 8968 my name is michael
  19. mike454
    alky help
    welll i pulled the tops off and the needles are all the way down would drilling some smaller jets help any at all?
  20. mike454
    alky help
    mine is doing like phelps said his was doing i can make 5 or 6 passes and still be able to hold my pipes without getting burnt im ganna try moving my needles and see what happens thanks for all the help everyone
  21. mike454
    alky help
    hey guys i have a 4 mill stock cylinder passion motor on alky and every time i make a pass by the time i get turned around its done loaded back up it runs great down the track it has a set of 38mm mikunis on it any ideas?
  22. there is a place down here by atoka its a good place to run
  23. im looking for a set of 38 or 39mm alky carbs brand doesnt matter just want some that work good just inbox me if anyone has any thanks
  24. going to decatur swap meet hopefully get rid of these extra banshee parts
