fck55mph Posted June 4, 2010 Report Posted June 4, 2010 Everything was fine on bike and one day it started then died after 5 seconds. No spark, coil tests out fine and even swapped it out and still same thing. I tested out stator at the wires coming out of flywheel area and it was in specs. I even tested stator at the connector where it goes into CDI..same..within specs. All grounds and wires are fine. So my question is, do these things just puke out like that? Just want other people who have had this happen to chime in. I have one on order from motor city atv(BHQ sponsor) but this is just driving me nuts. Also,all switches tested out fine and TORS has been disconnected and has never been an issue. Thanks for any input!! Quote
pr0blumz Posted June 4, 2010 Report Posted June 4, 2010 Everything was fine on bike and one day it started then died after 5 seconds. No spark, coil tests out fine and even swapped it out and still same thing. I tested out stator at the wires coming out of flywheel area and it was in specs. I even tested stator at the connector where it goes into CDI..same..within specs. All grounds and wires are fine. So my question is, do these things just puke out like that? Just want other people who have had this happen to chime in. I have one on order from motor city atv(BHQ sponsor) but this is just driving me nuts. Also,all switches tested out fine and TORS has been disconnected and has never been an issue. Thanks for any input!! My CDI failed because of a wire in my harness shorted out against the head on the motor. I have never heard of them failing for no reason. Quote
benb5241 Posted June 4, 2010 Report Posted June 4, 2010 Actually, my friends CDI just puked on his Shee, just one day it wouldn't start, nothing out of the normal, just wouldn't start. It ended up being the CDI just went out so it does happen out of the blue, its just very rare. Quote
fck55mph Posted June 4, 2010 Author Report Posted June 4, 2010 well,like i said, i checked everything..switches..wiring..all of it. with plugs out and kickin my banshee over, i get nothing out of the hot wire goin to the coil. so i did the same test on the blaster and the test light lights up. it has to be the cdi cuz the stator checks out..even at the plug goin into the cdi. just wish the damn thing would hurry up and get here so i can this thing goin...headin to silver lake dunes in a week. Quote
okbeast Posted June 4, 2010 Report Posted June 4, 2010 Check the plug cap, just cuz it's an easy thing to check. Quote
fck55mph Posted June 4, 2010 Author Report Posted June 4, 2010 Checked them..they are fine...even with the cap off...no spark to a grounded surface. Quote
camatv Posted June 5, 2010 Report Posted June 5, 2010 cdi's usually die one of 2 ways they just STOP dead no more at all OR the timing curve getss all wacky and it backfires and acts all shittty for no reason the way to test a cdi is replace it! if you have gone through all the wiring and the coil positive is not grounded and everything tests good i'd say the cdi in 15 + years i have only replaced 2 cdi's one on a 250ex and one on a 92 banshee with about 9million miles on the clock.. Quote
AKheathen Posted June 5, 2010 Report Posted June 5, 2010 give the cdi the "smack test".....i shit you not, that is a test. if it sparks after smacking it with the palm of your hand, there is a dry connection somewhere inside, and needs replaced. have you dug in and checked the stator/pickup? Quote
BellicoseBanshee Posted June 5, 2010 Report Posted June 5, 2010 So my question is, do these things just puke out like that? Yes, they can just fail without notice. It will work fine, and then suddenly fail without notice. CDIs are solid-state components, so they either work or they do not. CDIs cannot be bench-checked like a stator, harness, or coil... Quote
fck55mph Posted June 5, 2010 Author Report Posted June 5, 2010 give the cdi the "smack test".....i shit you not, that is a test. if it sparks after smacking it with the palm of your hand, there is a dry connection somewhere inside, and needs replaced. have you dug in and checked the stator/pickup? Yea, the stator tests out fine. I will try the "smack test" later on the cdi box and on the old lady later on tonight too!! Quote
camatv Posted June 5, 2010 Report Posted June 5, 2010 the smack test nice.. i usually use the drop kick in the street test with junk parts. Quote
AKheathen Posted June 6, 2010 Report Posted June 6, 2010 the smack test nice.. i usually use the drop kick in the street test with junk parts. whatever gets you ot of the woods.... Quote
fck55mph Posted June 11, 2010 Author Report Posted June 11, 2010 Just an update...it was the CDI box. Got another OEM and it fired right up. Thanks to all for advice. Quote
