Hey guys like the title says at full throttle it will start cutting out, then cuts out thereafter in all throttle ranges. It's done it ever since I have had it.
I have a 2 into one carb and have changed the main jet both up and down from where it was, with changing it down seeming to make it worse and changing it up does not do anything.
So far, I ohm checked the stator, the charging coil was 10.0 ohms where the spec was 13.7 ohms, everything else was within range. I measured the gap of the pickup coil to be about .018 inches also.
I also replaced the coil and spark plug caps with another set of each that I had laying around.
Other than that, I'm stuck. Thanks in advance.
