spun Posted April 26, 2010 Report Posted April 26, 2010 every time i rejet i seem to have this issue, sync up the carbs, put the pods back on. test run and what do you know i lost a pod! anyone else have this issue, stock carbs! what do you guys do to keep them suckers on? thanks Quote
spun Posted April 26, 2010 Author Report Posted April 26, 2010 LOL good thing you know the steps of getting them on.... got hose claps Quote
andrew3160 Posted April 26, 2010 Report Posted April 26, 2010 every time i rejet i seem to have this issue, sync up the carbs, put the pods back on. test run and what do you know i lost a pod! anyone else have this issue, stock carbs! what do you guys do to keep them suckers on? thanks What pods are you running, angled or straight ones? I know mine rest where the swing arm pivot bearing is or cases I cant remember and I have never had an issue. Quote
06specialedition Posted April 26, 2010 Report Posted April 26, 2010 I have stock carbs with pods and mine have never fallen off.... Make sure you dont get your outerwear inside the clamp. Quote
spun Posted April 26, 2010 Author Report Posted April 26, 2010 just strait one, no outer wear they sit on the top of the case, i dont get it i must be scewing something up the problem follows 2 sets of pods. you guy just putting the pods on dry and tighten the hose clamp right? Quote
james Posted April 27, 2010 Report Posted April 27, 2010 i ran a toomey 2-1 where the filter sets vertical, i welded a socket to the frame before powder coat. its perfect Quote
Snopczynski Posted April 27, 2010 Report Posted April 27, 2010 Take the pod and heat up the rubber on the outlet of it with a heat gun. Put it on the carb freshly warmed and tighten it down with a real hose clamp. Do not mess with it until its cooled off. It should stick on at that point. Quote
bansheesandrider Posted April 29, 2010 Report Posted April 29, 2010 Make sure you are using a quality clamp, not the stockers. Cascade used to sell some clampsthat did a real good job, I don't know if they still carry them or not. You might also try roughing up the inside of the filter with some sandpaper. Quote
AKheathen Posted April 30, 2010 Report Posted April 30, 2010 sccuff the outside of the carbs with scotch-brite, or sandpaper to get a rough surfface to stick to...and make sure it's not all oily.... i ndidn't have aproblem, either... Quote
banshee35005 Posted May 1, 2010 Report Posted May 1, 2010 maybe u need smaller pods wrong size maybe? ive never had a problem with mine they slide on snug them i just have regular hose clamps on them work great Quote
evro Posted May 1, 2010 Report Posted May 1, 2010 never lost one either....yet. i always prefer to use a socket when possible, i fuckin hate flat head screwdrivers...... Quote
HectortheHut Posted May 2, 2010 Report Posted May 2, 2010 Sometimes they slip off if you tighten the hose clamp too much. Quote
broncbob Posted May 8, 2010 Report Posted May 8, 2010 Make sure the clamp is on the bell of the carb, if the pods are sitting on the carb bell at a angle, and then you tighten the clamps, they never really get that tight. I have to slightly push my angled pods down the get then square on the carb bell. Quote
