jon321 Posted April 12, 2010 Report Posted April 12, 2010 See the red arrow pointing to the carb,well the carb hits the dam exhaust coupler if i try to rotate it and i cant use the zip tie trick cause the filters are to close togther.Why is it that the exhaust pipe is angled in further then the other one.The filter on the right side just barley even touches the pipe,I can get a feeler gauge in between that one,that ones not really a problem its the one on the left side. Hey guys throw out some advice or ideas you have to where I could clear that pipe .Thanks Just a side view pic of the filter,notice how its not seated flush and it sits sorta angled Just a tight ass fit This pic here is how much I have for play which is about less then a 1 inch,you guys think that if i had an angled K&N pod that it would clear that pipe? Quote
NickisGod Posted April 12, 2010 Report Posted April 12, 2010 have the same issue using paul turners and 38mm pwk carbs. at first i was using a flex tubing from napa, i used a 2.5inch nylon pre heater hose with steel reinforcement. then i decided that its a p.i.t.a. called duncan racing and they said "use a air box". so, what are u waiting for? put it back on, and if your stupid like me and grinded the tabs off he said "use the zip ties they use in law enforcement, they are nere bullet proof". good luck Quote
wacko2000 Posted April 12, 2010 Report Posted April 12, 2010 wow dude that is cluttered under there. What size carbs and filters are you running. I was running CPI'S 35's and pods and i still had plenty of room. I had the angled pods so im guessing thats what helped. I also have heat wraps on the stinger tubes so I do not burn up my pods or outerwears. Quote
alf44 Posted April 12, 2010 Report Posted April 12, 2010 those filters look huge for those carbs. there Mikuni's right? Are you sure you have the right ones?? What pipes are those? Quote
jon321 Posted April 12, 2010 Author Report Posted April 12, 2010 those filters look huge for those carbs. there Mikuni's right? Are you sure you have the right ones?? What pipes are those? CPI inline drag pipes, MIKUNI 34MM Quote
jon321 Posted April 12, 2010 Author Report Posted April 12, 2010 wow dude that is cluttered under there. What size carbs and filters are you running. I was running CPI'S 35's and pods and i still had plenty of room. I had the angled pods so im guessing thats what helped. I also have heat wraps on the stinger tubes so I do not burn up my pods or outerwears. the carbs are 34mm Mikunis and the filters i belive are 5 or 6 inches long by 2 3/4 round Quote
WINDYCITYJOHN400 Posted April 12, 2010 Report Posted April 12, 2010 I'd try (just for kicks) moving your front pipe mounts to the outside of the hangers. From the look of the pictures it looks like you have the tab from the pipes mounted to the inside of your billet front hangers. (Ever pipe seams to have it's own personality when it comes to fit.)Try switching it so they are on the outside. This will roll the head pipe out toward the frame and away from your filter. On some brands and styles, I've had to go to ACE and get 1/2" spacers to push the pipes out to fit so they wouldn't hit heads, frames, filters, Etc. Sometimes it works better to even put spacers on the rear hangers to angle the pipes away from the carbs sooner. Otherwise I'd get the angled K+N pods. Or some PWK'S. LOL. Keep us posted.... Quote
rdzbangshee Posted April 12, 2010 Report Posted April 12, 2010 See the red arrow pointing to the carb,well the carb hits the dam exhaust coupler if i try to rotate it and i cant use the zip tie trick cause the filters are to close togther.Why is it that the exhaust pipe is angled in further then the other one.The filter on the right side just barley even touches the pipe,I can get a feeler gauge in between that one,that ones not really a problem its the one on the left side. Hey guys throw out some advice or ideas you have to where I could clear that pipe .Thanks Just a side view pic of the filter,notice how its not seated flush and it sits sorta angled Just a tight ass fit This pic here is how much I have for play which is about less then a 1 inch,you guys think that if i had an angled K&N pod that it would clear that pipe? i have been thinking of making some carbon fiber tube extentions, 3 or 4 inches long ,by 2 1/4 or 2 3/4 inch wide, with a bracket to to hold it tight to the frame Quote
bbcmudtruck Posted April 12, 2010 Report Posted April 12, 2010 What are you running for an intake? Looks like it is spaced way out from the cylinders. You may have to get some up intakes. They will move everything alot closer to the cylinders. You might need to get some angled pods as well. Quote
robert.b.west Posted April 12, 2010 Report Posted April 12, 2010 I did not read a whole lot of what was said above but with my t-5's i have to get the K&N's with the 10 deg bend to keep them from touching the exhaust and i have header wrap to keep from burning my outerwears. here is a list of what k&n has http://www.knfilters.com/search/univround.aspx Quote
Boston Posted April 12, 2010 Report Posted April 12, 2010 i have the same carbs and pipes. i have the after market billet intakes with the angled pods from cascade and i have alot move room then you. i will only run the angled pods cause they pretty much sit right on the frame which helps with keeping them on. if you want a pic let me know Quote
Pasi S. Posted April 12, 2010 Report Posted April 12, 2010 Same problem here (like in the first pic) with T-5´s and 35 PWK´s. I use billet intakes from M&M and angled pods and I burned my outerwears also. Well - it works so I don´t give a damn... Quote
Boston Posted April 12, 2010 Report Posted April 12, 2010 i got that heat wrap from cascade and that stuff sure is sweet for not burning your stuff Quote
KlotzBanshee Posted April 12, 2010 Report Posted April 12, 2010 Get some angled pods and get rid of those giant reed spacers. That will move the whole asembly forward and give you the extra room. $.02 Quote
Boston Posted April 12, 2010 Report Posted April 12, 2010 Get some angled pods and get rid of those giant reed spacers. That will move the whole asembly forward and give you the extra room. $.02 what he said if there just on there for no specific reason id take them right out ! Quote
