Cali Posted April 7, 2010 Report Posted April 7, 2010 Have you tried pull starting it to see if you can get it to fire? Quote
fastquad02blaster Posted April 7, 2010 Report Posted April 7, 2010 If he's not getting fuel to it, it probably wouldn't be a good idea to pull it around without lubrication in the engine. Quote
gunner6262 Posted April 9, 2010 Author Report Posted April 9, 2010 If he's not getting fuel to it, it probably wouldn't be a good idea to pull it around without lubrication in the engine. agreed. the carbs arent new they are the carbs that came on the four wheeler which 28mm pwks slides. jet size? not all to sure to be honest. well i tried to dump more gas down the spark plug holes and got a rumble. it really wanted to fire today. but still would not run. so its obviously a fuel delivery issue. the plugs werent really getting wet. pretty dry actually. but anyways i cleaned the carbs and the jets rather well cleaned everything up and set the float height between 20-22mm. it has boyssen reeds. the reeds look good. no cracks frays or chips and i tried fliping then around but still no change. yes the pistons are in correct way. arrow point toward exhaust with the two ports on the piston skirt facing toward the carbs. so like i said its definitely a fuel delivery issue. so a carb syncing would be in order from what i hear but i though that was the point of the crossover tube. equals the pressure between both carbs so u did have to carbs sync. other then a possible carb sync i have no idea what the issue can be. ANY IDEAS??!?!?!?!?!?!?! Quote
gunner6262 Posted April 9, 2010 Author Report Posted April 9, 2010 agreed. the carbs arent new they are the carbs that came on the four wheeler which 28mm pwks slides. jet size? not all to sure to be honest. well i tried to dump more gas down the spark plug holes and got a rumble. it really wanted to fire today. but still would not run. so its obviously a fuel delivery issue. the plugs werent really getting wet. pretty dry actually. but anyways i cleaned the carbs and the jets rather well cleaned everything up and set the float height between 20-22mm. it has boyssen reeds. the reeds look good. no cracks frays or chips and i tried fliping then around but still no change. yes the pistons are in correct way. arrow point toward exhaust with the two ports on the piston skirt facing toward the carbs. so like i said its definitely a fuel delivery issue. so a carb syncing would be in order from what i hear but i though that was the point of the crossover tube. equals the pressure between both carbs so u did have to carbs sync. other then a possible carb sync i have no idea what the issue can be. ANY IDEAS??!?!?!?!?!?!?! so u wont have to carb sync with a crossover tube. my bad. i thought that was the purpose of it. plus if i need to buy jets where can i get them for my keihnin 28mm carbs without bein raped? Quote
gunner6262 Posted April 9, 2010 Author Report Posted April 9, 2010 so u wont have to carb sync with a crossover tube. my bad. i thought that was the purpose of it. plus if i need to buy jets where can i get them for my keihnin 28mm carbs without bein raped? lol sorry i have one last thing. i noticed my petcock is constantly dumping fuel into the carbs. there is absolutely no vaccum system on this from the petcock to the carb. i do have what looks like a vaccum port on the carb thats covered up. is this normal??? Quote
gunner6262 Posted April 11, 2010 Author Report Posted April 11, 2010 lol sorry i have one last thing. i noticed my petcock is constantly dumping fuel into the carbs. there is absolutely no vaccum system on this from the petcock to the carb. i do have what looks like a vaccum port on the carb thats covered up. is this normal??? No advice or ideas? Quote
Building my First Posted April 11, 2010 Report Posted April 11, 2010 There must be something off on the carbs. Are the idle screws in enough to have the slides off the bottom? Are you using the choke? Sounds like you really need to do a leak down test, you might have a massive air leak. Quote
gunner6262 Posted April 12, 2010 Author Report Posted April 12, 2010 Yeah I guess I will but I don't see how an air leak would cause no fuel to be delivered to the plugs. And yeah screws out 1 1/2 turns and I used choke but still dry plugs. And it's damn near turning over but I'll try the leak down tester. Quote
Smokestack Posted April 12, 2010 Report Posted April 12, 2010 I would pull the petcock and clean the screen in it. Then pull the jets out of your carbs and make sure of the size and clean them really good. Pull your air screw out and clean it really good too. Quote
Smokestack Posted April 12, 2010 Report Posted April 12, 2010 Yeah I guess I will but I don't see how an air leak would cause no fuel to be delivered to the plugs. And yeah screws out 1 1/2 turns and I used choke but still dry plugs. And it's damn near turning over but I'll try the leak down tester. If your reeds dont have a good seal the motor wont pull the fuel into the cylinders very well. Same for most air leaks from what i have heard. Quote
