banshee2007 Posted March 8, 2010 Report Posted March 8, 2010 I have a 2000 banshee with a motor that is highly modified. all motor work was done by professional shop. motor has less than 10 hours on it since done. Like new 4mm stroker crank with spacer plate--$350.00 Ported cylinders--bored 60 over with like new pistons and rings $450.00 clutch basket assembly with new clutch assembly $175.00 clutch cover w/waterpump assembly $75.00 stator cover $20.00 flywheel $50.00 stator assembly $100.00 upper & lower cases--good shape $175.00 stock carbs--bored & jetted--no tors $150.00 foam filters with 4" extensions and outerwears $45.00 radiator assembly with cap $55.00 Toomey TR6 Chome pipes and silencers--dent in bottom of silencer, one pipe has small ding $295.00 motor mounts $10.00 aftermarket chrome headlights--small $15.00 thumb throttle $30.00 milled stock head $25.00 stock shifter $5.00 complete like new tranny $300.00 kick start lever $35.00 front stock shocks $45.00 rear stock shock $50.00 swingarm with good bearings $75.00 bearing carrier with new bearings and seals $35.00 stock axle---straight--good splines and threads axle nuts included $65.00 rear hubs $40.00 front a arms, spindles, hubs, rotors, all bolts included $150.00 blue radiator plastic $30.00 blue gas tank cover $25.00 on/off switch assembly $25.00 front brake mastercylinder and lever assembly $20.00 rear brake mastercylinder $20.00 front & rear brake lines $25.00 rear grab bar "stock" $25.00 complete wiring harness $50.00 cdi box, voltage regulator, and coil assembly $75.00 rear brake caliper with pads $45.00 rear brake hub with rotor $40.00 rear sprocket hub with new renthal sprocket, new blue o ring chain, and new 13 tooth sprocket $100.00 stock gas tank and petcock $25.00 frame silver--good shape $400.00 front fenders race cut blue $45.00 rear fenders blue uncut $75.00 jaw bumper--bent--$20.00 nerf bars--good shape $65.00 Stock front rims--great shape silver $90.00 stock rear rims very nice $85.00 Prices do not included shipping. Prices are also negotiable.. shipping will be done thru ups unless a cheaper route is found. paypal is preferred payment method. pm questions. if you need to see pics pm your email address to me and i will get pics forwared to your email. Quote
ugottalovewagner Posted March 8, 2010 Report Posted March 8, 2010 can i get a pic of those headlights? you can send it to [email protected] thanks jeremy Quote
08 BANSHEE Posted March 8, 2010 Report Posted March 8, 2010 Like new 4mm stroker crank with spacer plate--$350.00 E-mail pics of the 4 mm stroker and plate to: [email protected], thanks dude. Quote
tenringx Posted March 8, 2010 Report Posted March 8, 2010 Can you please send pics of the rear fender to [email protected]. Also a shipping quote to 72764 (Springdale, Arkansas) Quote
BIGONTS Posted March 8, 2010 Report Posted March 8, 2010 Please send pics and price shipped of the filters and outerwears for stock carbs to Burbank, IL 60459? [email protected] Thanks Quote
Howsahemi Posted March 8, 2010 Report Posted March 8, 2010 I'm interested in the on/off assembly. Does it have the key with it? Quote
BluBanshee98 Posted March 8, 2010 Report Posted March 8, 2010 Would you do 50 shipped via usps to 99506 on the flywheel? I know for a fact usps would be the cheapest method! Let me know thanks. Quote
GhostRider Posted March 8, 2010 Report Posted March 8, 2010 pics of stator and flywheel to [email protected] Quote
WantABanshee Posted March 8, 2010 Report Posted March 8, 2010 pics of headlights to [email protected] THanks Quote
BluBanshee98 Posted March 10, 2010 Report Posted March 10, 2010 Still parting it out??? No replies! Quote
