GhostRider
Everything posted by GhostRider
  1. to be clear more the first vin i posted is the 2002 banshee that i was buying the second vin (the stolen) was to compare it with the 2002 so i know if its a-arm or j-arm
  2. Hello the first vin that i posted it here was for the 2002 banshee that i was looking to buy from a guy in my country (kuwait) its not in america. the second vin number (the stolen banshee) i dont exactly remember from where i got it maybe from ebay, i posted it here to know what kind of arm the 2002 was because it has same letters, i thought its a j-arm as i said before here, i dont know the owner of the stolen banshee i dont live in america. i added you justin in msn. thanks
  3. this is happend to me yesterday, i replace the float needle and the problem got fixed
  4. PROBLEM FIXED... It was the float needle
  5. as the topic says ... before 8 months i take off the carbs and cleaned them, didn't installed them, today i recieved my other parts so i installed everything, installed the carbs but i notice a huge leak of gas from the bowls... they were fine before... and didnt used them.. so what you think?
  6. open the clutch cover and check the kicker and idle gear..
  7. will u sell the rear eom rims only without tires?
  8. Is the throttle switch: it connect with the front brake lever plug? or the throttle connecter? 9. Is the killer switch: which plug this one connect to?
  9. hi guys ... i need help knowing my harness 1: (2 black wires) 2: key 3: on/off & lights 4: (2 wires black/green) 5: coil 6: headlight 7: headlight 8: (3 black wires) 9: (2 yellow wires) 10: tors/ not sure 11: tors/ not sure i need to know 1/4/8/9/10/11 can anybody help? i removed the parking brake wire + throttle wire
  10. as the topic says .. im looking for a flywheel, stator, timing plate, got any?
  11. do u have flywheel/stator/timingplate?
  12. anyone? i'm looking for flywheel stator timing plate k&n pods for stock carbs
  13. can i do leak down test without the flywheel and stator plate? i mean can i do it with only case/trans (no clutch basket)/crack/topend... without the cooling lines that comes from radaitor?
  14. so i cant wash it with premix gas? one of my crack bearings is shaking, i will go to the dealer and buy new one... all seals are good.. what do i need to check guys while the engine is dissembled? gonna put coolhead for the first time, bought a 20's domes
  15. Hello guys ... i need some help, i'm ressembling my motor, the motor was parted out from along it, and there's a dust everywhere.. gears, crank.. etc what i want guys is how to clean them, do u clean them with premix gas? and what parts needs to be greased... about the swingarm and carrier, i dissembled them from along time, what parts needs to be greased and how about the touring bolts? anyone have a picture of the banshee harness? i removed it now wanna install it but dont know what place to put in.. Thanks
  16. need flywheel, stator, timing plate, do u have? if yes send pix to [email protected]
  17. As the topic says .. i need flywheel/stator/k&n pods with outwears...
  18. pm me ur paypal account need the stator and if you have flywheel let me know
  19. i'm looking for banshee case... both sides in good condition, no chain damage, all mounting threads are good, no cracks or repairs..... ready to install [email protected]
  20. need flywheel and stator.. pics
  21. do u have flywheel & stator?
  22. send pix to [email protected]
