Hey whats up guys Iam new at this but i need some opinions on some dome sizes for my shee, I just got it bored .60, iam at 9,969 ft. and the domes are for a cool head. any info would help
what other mods you got? if ya wanna run pump gas youll need 21cc or bigger domes but its also gonna depend on your compression. list all your mods and youll get a better answer for sure. :cheers:
didn't know banshees could ride on clouds. I would image at that elevation you would be able to put a real small dome in it and still stay on pump gas if that's your intention.
What is it, under 160 psi to still run pump gas? I don't know if you can even get to that at 10k ft.
Yeah Iam way out here in the hills lol, were pretty up in elevation, My mods are: FMF Fatty's with power core II's, stock cylinders with .60 bore, forged wiseco pistons, stock stroke crank trued welded,Vforce II reeds, toomey air filter kit, and cool head, and i wanna run pump gas, Oh snap I mean 6,969 feet my bad
Edited by sketch2
You should be fine with 18cc domes on premium pump gas unless you take a trip to lower elevations.
-David
-David
X2, ran some 18 in tucson. elevation 2,389. bike ripped
21cc domes will give you less compression than 18cc domes. At your elevation, the smaller domes will help compensate for the loss of barometric pressure. 21cc would be better than a stock head but 18cc would be safe.
-David
