VWMIKE Posted January 22, 2010 Report Posted January 22, 2010 Hey Guys, Don't post here much, but do read the forums quite often. Doing a budget build on my banshee, and just picked up a used pair of pwk's off ebay, supposed to be in good condition. What I noticed right away when i took them out of the box is the slides have a fair amount of slop in them. With the throttle closed if you push the bottom of them front to back there is probably 2mm of play in them? How tight are they new? Anyone come across this before and are they useable? thanks Mike Quote
J-Madd Posted January 22, 2010 Report Posted January 22, 2010 I don't think the slides ever wear out. Clean 'em up, jet 'em accordingly and run 'em. Quote
jbooker82 Posted January 22, 2010 Report Posted January 22, 2010 Mine are nice and tight. I spray them with a lite coat of cable life lube. It is designed for cables, and carb slides. Quote
getonit Posted January 26, 2010 Report Posted January 26, 2010 carb slides can and will get wore out, takes years but you will see erratic behaviour in idle and big bogs when you stab the throttle, almost like they do when the rings start to go. Quote
