521cc 10mil cheetah motor
Built and ported by nano that used to work at d&m racing
72mm pistons (new)
165 psi comp
10mil crank new from crank works
intakes for 39-41's
1-5 override (rudy kurtz)
vforce reeds
new vortex clutch basket
new clutch
direct drive lockup
lightened fly wheel
advance plate
new stator
Motor maybe has a few hours of run time compression test is perfect, with 150lb rider in a stock modified chassis was doing 78-80 at olds hill.
options:
motor with everything listed above - $4200
motor with everything listed above and 39 pwks/billet bowls - $4550
motor/carbs/shear big bore hand made- $ 4900
please pm me with any offers/ questions
call or text for fastest response 623 628 7778
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
  • 1 month later...
72mm pistons (new)
165 psi comp
intakes for 39-41's
vforce reeds
new clutch
direct drive lockup
lightened fly wheel
advance plate
new stator
options:
Hey dude, this !NEW 10mil engine! you sold me for $3200.00 is very much used, it broke down on the second run at banshee hill, upon tear down inspection, surprise surprise, you ripped me off, return my money for the engine as you said you would, you have been avoiding me and not answering my messages, I will post pictures of the engine parts for you and other members to view. MAKE IT RIGHT ***13RAZOR13***, YOUR EXCUSES DO NOT MAKE SENSE ANY MORE.............
Shitty deal.
Just curious, what did you find upon tearing down the motor?
Thanks for asking, found a badly worn, used and twisted crankshaft with a poor epoxy pach that blew out of the upper crankcase that looked from a previous repair.
DAMN!!! This was only ran a couple pulls before you bought it?
here is the "brand new crank from crankworks" = used stock crank, looks like it was stroked to a 10mil by a&s ....i called crankworks and it was rebuilt about 6 months ago.. Still not a new crank from crankworks...
rudy kurts tranny= tyson shift drum, im assuming he cut the tranny as well..
new vortex clutch basket= a very used and chewed up basket, later he told us that one of the arms on the lockup came off and thats why it was chewed up.."new?"
new clutch= come on man, u and me both know that thing was smoked!!!
the first run at dumont the crank twisted and blew a hole in the cases, caused a lean condition and melted the pistons and head...brand new motor?
thats a fucked up deal .. hope he makes it right.
i will say , anyone that buys a "NEW' or USED motor , should tear it down as soon as they get it. seen to many "NEW' motors go boom.
