Mjv420
Everything posted by Mjv420
  1. good condition, 125 shipped.
  2. buuuumppp
  3. Basket sold I have 2 rear shocks, PM sent.
  4. Come on HQ, accepting reasonable offers on this stuff. Need this stuff gone and im willing to hook you guys up!
  5. Located in southern indiana
  6. bump/ Got 2 sets of bare cases, anybody?
  7. Have some parts from a 87 KX 80 if anybody is needing anything/
  8. Yes I do have one rear brake pedal No sorry.
  9. Pictures sent sandshots. Guys Ive got alot of good useable parts here, would really like to sell the transmission so feel free to make a reasonable offer on it.,
  10. bump $165 shipped for the tranny $55 shipped on the bars $30 shipped on the crank. $80 shipped on the arms.
  11. Pro Taper Henry/Reed 7/8 bars Stock set of a-arms. Balljoints are tight on all 4 arms, upper left arm is slightly bent , the dustboot also has a tear, I never noticed anything abnormal while these were installed. No rips in the dustboots on any of the other arms. there are dents/dings/rust/left over can paint on the arms.
  12. Ive got a stock tranny that is complete, any takers? Got a stock stroke crank, rods and bearings are good. Threads on the crankshaft were a little boogered up, I ran a die on it and never had any problems with it coming loose when the bike was together and running, good deal for somebody looking for a cheap crank. Still got some other stuff, ive just been lagging due to having to disassemble stuff and clean it up. If your needing something just shoot a reply here.
  13. bump taking offers
  14. I do have rear rims, make me an offer on em.
  15. I will let you know tonight. 2001, but i spliced the old style connector on it, i did save the original connector but i will have to dig for it. Rod bearings are tight on the crank, the flywheel side shaft is balloned. Bottom end is together right now, slight chain whack, not bad at all, no flywheel or stator. PM sent.
  16. Sorry no exhaust springs or rubber seals. Here is a general list of what i have. bottom end set of cases steering stem 2 rear shocks 2 front shocks a-arms spindles and rotors front brake calipers rear brake caliper wiring harness 2 radiators 2 clutch covers good clutch basket/inner hub rear grab bar 2 water pump covers flywheel side cover rear linkage a-arm frame with no subframe some misc. stuff im sure i couldnt remeber. If you need something just ask and ill check
  17. I will check and get back with you Yes
  18. Bump
  19. No stators.
  20. Ive got a bunch of stock parts that need to go, if your needing something just shoot me a reply and we'll work something out. Mike
