Gman-7m
Everything posted by Gman-7m
  1. Is those lectrons the same ones you are selling for $325.00 ,thanks Sent from my SM-J700T1 using Tapatalk
  2. how bout some pictures?,
  3. thanks...
  4. Looking for Clippard power jets, any one knows where to get them or the part #, thanks....
  5. Thanks for the reply...
  6. Gman-7m
    39 or 40mm carbs
    Pm sent
  7. Hi, any one know where I can buy clippard power jets?, thanks help will be appreciated...
  8. find carbs yet?, I have a set of 39mm pwk pumpers with clippard power jets and pump.
  9. no problem, thanks...
  10. Gman-7m
    T5 pipes
    I have a nice set, very clean, found any yet?
  11. Gman-7m
    Single carb
    E-mail sent on lectron set up>>>
  12. find anything yet, I got some if you need it: 4mil dune port oem cyl, @ 192deg exhaust and 125deg transfers, new bore to 65mm, new 795M06500 wiseco pistons, mod quad cool head with stroker domes. . Gus:702-675-1691
  13. Foo, you sound as if you are wanting to buy a serval, at a stock cylinder, high quality ported complete top end!
  14. Silenced big bores?
  15. I have a set with reservoirs that need cleaning and charge, $200.00 shipped, i can text pictures... 702-675-1691
  16. Old post but, would loose squish or very high port timing cause the same symptoms?
  17. I have a set of alkys with pump with clippard power jets!!!
  18. You are very very welcome, there is more good people to deal with here on Bhq...
  19. this sounds like a ghost sale...
  20. They are both wiseco numbers but the real difference is that 10018 has piston intake ports and 423mo has none and that piston belongs to a Kawasaki triple, I hope that helps, I just got done porting a set for a super cub build oh, I forgot to mention that the 72mm blaster pistons are 2mm below deck.
  21. I won them on Ebay, I had no Idea this were yours. lol.
