UTYFZ350 Posted August 19, 2009 Report Posted August 19, 2009 Hey guys, went out 2 weekends ago with the shee running sand mountain Ut, i have to say my banshee still impresses me, however i finally got beat by a 450 (not a huge fan of 450s at all) prior to this my only losses were to alcohol banshees, turbod raptor, r1 swapped raptor, and a built predator on nitrous, well this 450 supposably only had bolt on mods which i called bs but his friends had stroker kits and this would still beat it, whether they were just makin it up or not it bugged me getting beat, so i would like to make it a little bit faster, what can i do? here are my current mods Toomey t-5 pipes pro design cool head upgraded carbs k and ns with outerwears direct to carbs ricky stator stator/timing plate set at +4 what i would like is morepower/speed without sacrificing reliabilty, since i have had this bike its been 2 kicks and its alive, can i change domes in the cool head to increase compression and run race gas without having to retune? what would you guys reccomend? Quote
SonOfSand Posted August 19, 2009 Report Posted August 19, 2009 What size domes do you have in right now? I have almost the identical setup and run 20cc domes. I ride at St. anthony dunes, so we are the same elevation. I have been running pump gas, my comp was 140/140. If you have anything bigger than 20cc domes you could gain some power there. I think after that you will have to port to get any real gain. I am in the middle of doing all that as we speak, should get my cylinders back from Kevin anyday now. Quote
UTYFZ350 Posted August 19, 2009 Author Report Posted August 19, 2009 (edited) forgot to mention that, i think it has porting as it has engraving on it WMR on one side and like willy mac racing or something on the other which leads me to believe it does, any way to tell for sure? also im not sure which domes i have, when i compression tested i was at 140/140 as well Edited August 19, 2009 by UTYFZ350 Quote
jbooker82 Posted August 19, 2009 Report Posted August 19, 2009 Dune ported 4mill with cut stroker domes. That way you can claim your banshee is only bolt on as well. Quote
oh6banshee Posted August 19, 2009 Report Posted August 19, 2009 (edited) Everytime this question gets asked it always boils down to a port job,(if one hasn't been done)! You should go to herrjugsracing.com and check out the video section. this one is my favorite, stock carbs and a dune port baby. For $300-$350 how can you go wrong, I was going to get one my self but I got another banshee instead, so maybe soon now :biggrin: Edited August 19, 2009 by oh6banshee Quote
UTYFZ350 Posted August 19, 2009 Author Report Posted August 19, 2009 anyway to tell if it has been done? i have a good machine shop local some of you may have heard of, lindsay machine, but like i said it has engraving on it but not sure if its for that reason Quote
KEVSWS6 Posted August 19, 2009 Report Posted August 19, 2009 What size domes do you have in right now? I have almost the identical setup and run 20cc domes. I ride at St. anthony dunes, so we are the same elevation. I have been running pump gas, my comp was 140/140. If you have anything bigger than 20cc domes you could gain some power there. I think after that you will have to port to get any real gain. I am in the middle of doing all that as we speak, should get my cylinders back from Kevin anyday now. I think yours went out today. Quote
SonOfSand Posted August 19, 2009 Report Posted August 19, 2009 I tracked it, you are correct. I cant wait to get this back together, I haven't told some of the guys I ride with... I am hoping for the "Pearl Harbor" effect. Quote
DallasGDub Posted August 19, 2009 Report Posted August 19, 2009 A simple way to see if any work is done is to take the reeds and intake off and look at the inside of the cyl. We cannot tell you what has been done, but we can tell you if something has been done or if it is still stock. If you have the cyl off, Kevin will be able to help with measuring to know how aggressive your port work is (if any). Was the 450 stock that beat you? and retuning after any mod is the smart thing to do. Quote
pr0blumz Posted August 19, 2009 Report Posted August 19, 2009 Dune ported 4mill with cut stroker domes. That way you can claim your banshee is only bolt on as well. :thumbsup: Quote
00tbanshee Posted August 21, 2009 Report Posted August 21, 2009 i ran one of kevin's 4mil stock cylinder drag ports,but ran 34mm carbs.with the stock head you'd of thought it was stock.man did it ever turn some heads and beat some big motors! Quote
