for any of you running 300ft, how long do i want my swinger? about to have one made by a member on here, im running a 4mill FAST drag port......i was thinking 8 over......i weigh right at 195lbs and its a wheelie toting monster stock length
Thanks
Brad.
I was gonna mention the same, I would think 10 would suit your needs nicely. There may still be times when your on the back tires, but with the correct amount of slip all will be well.
hmmm, i appreciate all the advice fellas, i just dont want to go to far out, and not have enough weight to make it plant and it blow the tires all the way down the track......id rather it come up a little and have to use my wheelie bar than to go out to far and have it up.... so everybody pretty much agrees 10 over for a 4mill FAST drag ported stockers on dirt/clay
Thanks
Well, as mentioned, if you are going to be using a bar go a little shorter. If you are going to dune race it +8 or less will be a handfull. I run a 10 mill cub and I weigh 190. It has a +14 on it and you could flip it over on top of yourself every run if you wanted.
Paddle also plays a big factor in swingarm length as well. If you don't have much paddle, you aren't going to get traction w/an extremely long swinger. Weight, paddle, swingarm length all need to be considered together.
Thanks, but I will not be in the sand. Last line of my post says dirt/clay. I've never rode in sand so I dint know if it hooks better than soft dirt or what. We run wedges here or 4 snows. Thanks again for ur time.
well im trying to get away from a wheelie bar, so ill guess ill go +10, but then again running 300ft on the back tires would be a nice show too with the +8 , win or lose :evil: hahahha thanks fellas....
^^^^Yea I was thinking the thing. It''s got a little negative angle to it.
