Natemills8
Everything posted by Natemills8
  1. No body?? If I got a couple pictures I can see if your intrested just text me or call me at 606 627 1024
  2. Thinking about trading my drag bike to a motorcyle if I can and can get something I want everything thats done to the bike is in my sig this bikes only been ran 4 weekend no tuned in yet Ive got it to 3.90s in 200ft with a 300lbs rider not littler than a 750 and no older than 1998 Can get pictures if you want Message me if intrested
  3. Send me some pictures to [email protected]
  4. I dont see why anything would be wrong with it but I might be wrong.
  5. Let me know what you guys got like to get a set of 16cc or 17cc domes
  6. Let me know what you guys got.
  7. Outback Its like its hookin to hard off the line for the motor to pull but when it does wanna go it gets out about 10 feet & runs out of gas so times. I think it was in the wiring my buddy messed with it alittle & the left side richend up
  8. This is the back of the slide:
  9. Well there not pjs it says PWK on the side of them so Im guessing they are 35s then its got s d shaped slide ill find a picture so you can tell me what they are
  10. Then Keep them stopers on it you dont wanna be out on a trail a few miles from the truck or your house and a reed brake off if you wanna do anything open them up alittle bend then open some but not a whole lot
  11. Are you gonna trail ride or drag race?
  12. How can you tell the differnce between a airstriker and a regular PWK.. it dont have any problem with the throttle I just need to know what size piolet jet I need its a 35 right now me and my buddy think I should put a 30 in it and see how it does its to rich right now Im guessing if I can start it on fog gas the 2nd kick
  13. So go down a size is it a 34 or a 30? I can turn the powerjets off & the air screws out 3 turns & it will run & not run out of fuel goin down the track
  14. In your Sig it says you done got 35s just sent them to jeff or kim at K&T or Dan at A&S and get them set up for alky Im not knocking on PJs but ive never see a set run on alky. My self I like the PWKs
  15. Its a stock stroke stock bore ride ported motor my buddys 4mil cub with 35.5s on it has a 48 jet in it he said I might need to go smaller but it will start up with out the choke the second or third kick
  16. Did you have it part & look at the clutches? if so was your steels blued or was your fibers really slick like?
  17. What size Pilot jet should I be useing my bike is Stock Bore With Superstock Piston with a full drag port 34mm PWK Air strikers on alky with GGR Drag PipeSB. They are 35s right now I just need to know if I should go bigger or smaller or lever them alone
  18. Its just what your riding style is and how comfortable you are with your bike my self I like the comfort of a wheelie bar
  19. It wouldnt hurt to pull and check your plugs
  20. Go get yo some Maxima 927 that suff you used isnt clean enough for a bike my buddy did the same thing but used weedeater oil becasue it was the only thing he could find and it screw his bike up
  21. I mean what brand of oil are you using.
  22. did it have the pipes on when you got it from your buddy or did you recently just put them on? what kinda oil are you mixing with your gas?
  23. 8 over with wheeliebar or 10 over with out Id say
  24. if the reed padle just vanished they is only one place for it to go & thats in to the cylinder.Ive got v force 2 I dont know the life span I honestly would like to know too I need some new one but reed padles dont just vanish
  25. Just wondering how did you mix your gas? how many oz to a gallon?
