i got it to run some what better before i couldn't Evan ride it it would bogg under load and i found out my needles were out of wack.. i have a 280 mains 30 pilots and 3needle clip and 1 1/2 turns out on the aircrews 13:45 gearing.. when i do a cold start with no choke and i try and rev it some it bogs some what but it will still rev up.. it only boggs in the low end when i get into the power band it feels real strong..
http://s59.photobucket.com/albums/g296/ron...icture082-1.flv
http://s59.photobucket.com/albums/g296/ron...icture081-1.flv
you can hear the bog i am talking about in the vid i took this was when i had my old top ends. i picked up some low hour top ends with pistons and it still does it.. and both plugs were wet.. any help would be great, i am tryin to take it out riding on sat and i don't wanna blow it up :/.. thanks Ron..
to me that just sounds like the echo of the airbox lid not on... sounds fine to me, maybe, if it responds poorly lean your airscrews out, but if you put your lid back on ill bet you dont hear that deep blurp
plus, depending on your elevation and mods I would guess that your pilots may be too big, but Im not a banshee expert just trying to help cause Ive been there.
Sounds real rich down low, how dirty is your air filter.
Also whet shape are your reeds in, broken, chipped, cracked, sitting up of the cage?
ok thanks for the replys guys, yea the filter was a little dirty but its clean now.. yea its a little fat on the pilot jets.. i do have some 27.5 pilots should i swap em in?. the reeds are good they were just replace with boysin reeds. i don't have a air box lid but ill try and get 1 local, i need one any way cause my trails are wet and i don't wanna suck up any water. and i am pretty much at sea level. the only reason i was thinking it was still lean was cause when i pull out the choke half way it seems to run some what better..
i took it out today and i couldn't ride it with out the choke being half way on, i could some what ride it but it would just back fire out the right pipe. and as soon as i would pop the choke out it would go away. any ideas?.
i have the 27.5s in there now 2 1/2 turns out on the air screws.
http://s59.photobucket.com/albums/g296/ron...t=Picture-2.flv
i got a little vid it sounds good but its running a little rich..
Well if it ONLY runs better with the choke on, you are LEAN, stop riding it and fatten up your jetting man or eventually say bye bye to those pistons. :ermm:
Also i would do a leak down test to MAKE SURE you have no air leaks, its common practice on ANY Motor and should be done. Even if its been together for awhile. It cant hurt to check but it will probably hurt your motor and pop it if you don't make sure, its your call if you want to check.
Its very easy to do, so you might as well.
You can build one right here for 20-30 bux. every tool box should have one regardless. I sure do. http://www.bansheehq.com/forums/index.php?showtopic=110585
Good day!
Edited by savage420
ok, uhh idk i had 30 pilots and i was told that was too big and now its ruuning lean with 27.5s lol.. ugh this damn banshee hahaha.. what would cause it to back fire or w/e out the right pipe. cause when i started it and road it for a about 3mins with out choke them it starts to spit pop w.e then i pulled out the choke and it cleared up any ideas.. i was thinking of just buying the 2 into 1 intake and be done with the whole 2 carbs haha..
If you are running better with the choke out, you need to go bigger on the mains.
are you sure lol. i didn't think the mains effected bottom end?. i have some 300mains i guess ill give them a try...
i dropped the 30 back in, and the right needle had up and down play in it maybe that could cause this?. i had some spare slides and i droped that 1 in and i put the tors tops on so it will idle.. ill try and run it later and see how it does.
