mofoka Posted June 3, 2009 Report Share Posted June 3, 2009 Hey guys I'm not liking the way my 'white' IMS 5.7 tank looks.... one its stained and the white doesn't match anyways. I was thinking to paint it with regular spray cans, but is there a trick to painting these gas tanks? Quote Link to comment Share on other sites More sharing options...
Bill Posted June 3, 2009 Report Share Posted June 3, 2009 You cant paint those tanks, hell I couldn't even get a sticker to stay on mine. The gas fumes breath threw the tank and will bubble up anything. Quote Link to comment Share on other sites More sharing options...
desertdeweller Posted June 3, 2009 Report Share Posted June 3, 2009 thats strange mine is very white maybe they have an off white color or natural or something. I haven`t had any issues with stickers on mine at all. In fact I took some stickers off and am having a hard time getting the glue off. I saw a advertisement for one of the spray can companies they have a new line of paint out. It is supposed to stick to plastic very well can`t remember the brand though Quote Link to comment Share on other sites More sharing options...
278 Posted June 4, 2009 Report Share Posted June 4, 2009 Sand it with some 220 grit or a scotch brite pad, use some white Krylon fusion paint, then clear coat it with some dupli-color engine enamel clear coat, its the 500 degree stuff... It is chemical and gas resistant, so it will keep anything from happening to the paint, and the fusion paint supposedly bonds to the plastic 1 Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted June 4, 2009 Report Share Posted June 4, 2009 Sand it with some 220 grit or a scotch brite pad, use some white Krylon fusion paint, then clear coat it with some dupli-color engine enamel clear coat, its the 500 degree stuff... It is chemical and gas resistant, so it will keep anything from happening to the paint, and the fusion paint supposedly bonds to the plastic It's chemical and gas resistant if they get spilled on them. The problem with plastic tanks are that they are porous, the gas will cause the paint to bubble from under because it will not let it hold to the plastic. Quote Link to comment Share on other sites More sharing options...
rinaldobailey Posted April 4, 2013 Report Share Posted April 4, 2013 i dont reconmend painting it, i painted mine i sanded it with 220 320 lightly with 180 then lightly sandblasted then sprayed adhesion promoter and painted with base clear. it lasted a year and then it bubbled like crazy i ended up scraping it off and sanding it smooth put some stickers on i poked a bunch of holes with a needle so the tank can breath it seems to help with stickers staying on. Quote Link to comment Share on other sites More sharing options...
Glenyboy Posted April 4, 2013 Report Share Posted April 4, 2013 Could it not be hydro dipped? Quote Link to comment Share on other sites More sharing options...
toytech Posted April 5, 2013 Report Share Posted April 5, 2013 nope! i usually just check the last poster lol on a side note.. im all ears if there is a way to change them color. have vegas jeff make a vynal cover for it Quote Link to comment Share on other sites More sharing options...
