desertdeweller
About desertdeweller
  • Birthday 04/23/1969
Contact Methods
  • Website URL
    http://
  • ICQ
    arizona
  • Interests
    racing, hockey
    99 banshee cool head t-5`s works front and rear + 3 fireball racing arms 5 gallon ims tank 2-1 intake for now trying it out.
desertdeweller's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. lonestar has set up info on their website
  2. might try lonestar or fireball racing http://www.fireball-racing.com/
  3. I had used one for flat track and had the same problems. I ended up clearancing the block a little to get it to fit.
  4. yep a small flat head start with one and spiral it off, Its a blast to do have a good time.
  5. I never did a whole lot of big jumps but I cracked the stock swinger a lot doing desert races. It was always cracking in the area of the square cross tube where the linkage mounts.
  6. av gas will last longer than the pump gas. A small engine class I took a few years back the instructor said. Most 2 cycle premixes already have a fuel stabilizer built into them. That is because the manufactures realize that premix is typically used for sport or occasional home use like weed eaters. Where fuel can go bad quickly from sitting in the sun, garages etc.. To cut back on claims and reputation that their oil was the fault of an engine seizure when it was from bad gas and not the oil.
  7. I just added +2 to my bike haven`t had it on the trails yet, but I don`t think I am going to like it for trails. Just running it up and down the street it does take a lot more effort to wheely it. which can be good and bad for the trails depending on the situation. The one thing I did notice is the lack of braking from the rear end now. I have to slide back a lot further on the seat to try to keep traction on the rear to stop. If its that bad on asphalt I am sure the loose dirt around here will be horrible to stop it. But I will try it and see.
  8. after the suspension get a steering stabilizer it will help reduce the fatigue a lot.
  9. depends on the riding you do. Do you really need more motor or do you need better suspension? all the power in the world does you no good if the suspension can`t handle what your going to put it through.
  10. I guess dirty and I were on the same wave length this morning
  11. to run all that electronics you will also need to probably upgrade the charging system and install a battery to power the ecu. something to think about.
  12. thats strange mine is very white maybe they have an off white color or natural or something. I haven`t had any issues with stickers on mine at all. In fact I took some stickers off and am having a hard time getting the glue off. I saw a advertisement for one of the spray can companies they have a new line of paint out. It is supposed to stick to plastic very well can`t remember the brand though
  13. I run them also 23" front 22' rears I have rune that set up for years. I would run anything under a 22 with all the rocks around here on the trails
  14. check your float level maybe even set it a tad on the high side you may be running the bowl out of fuel. I have had that problem with dual carbs on a long steep hill with a single you have cut your capacity in half. I am not sure if you can buy a larger needle and seat for those to increase the flow or not. just another option to check if you run out of other ones.
  15. A co worker hiked it about 6 months ago. he told me the tribe at the bottom had quads down there. I am not sure if those are the ones for the tour or not but he said everything had to be flown by helicopter there. All of the tribes supplies, parts for the bikes, gas etc.. I don`t know if they have any that you can take your own bikes to or how you would get them there. something that would have to be looked into
