hey guy i was just wondering if having a 14t sprocket in front and 42t sprocket in the rear make my motor work hard. i was thinking of going back to 13t and 42t.
What kind of transmission are you using?
IMO, a 15-42 would be even better than a 14-42 with cub power. I do not think you will want 13 up front with a cub. A lot will depend on where you ride and what transmission set-up you are using...
stock is 14/41. no reason you should have trouble pulling 14/42. it will be easier on the motor.
Keep in mind, that the bigger the chain wheels you use, the longers the chain wheels and chain will last. :thumbsup:
It could depend on alot of things to get the best performance out of your setup.. For example, are you drag racing, your weight, tire size, tranny, etc.. But yea a 14-42 should work.
ther u go, tire size will be a big factor in gearing, as well
You have an override in that thing? Reason i asked is i do and i find with 15/41 5th gear isnt fast enough in a drag race. But if i put pro wedges on my bike, it's more than enough. Which is good cuz my n-down 1-5 dunable doesnt have 6th.
I gotta be pushing noticeably less power than you so i dont think you'd have trouble pulling that at all. If you do, you have issues imo.
What type of riding/racing you will are going to do?
im running a stock tranny with no override and running 8 paddle haulers.
i only ride in sand.
but i dune and race half and half.
Ah yes sand. Something i've never ridden in :(. Nevermind what i said then. Sorry.
one day....ill get to ride in sand.
Edited by RagunCajun
