steven Posted May 4, 2009 Report Share Posted May 4, 2009 hey guy i was just wondering if having a 14t sprocket in front and 42t sprocket in the rear make my motor work hard. i was thinking of going back to 13t and 42t. Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted May 5, 2009 Report Share Posted May 5, 2009 What kind of transmission are you using? IMO, a 15-42 would be even better than a 14-42 with cub power. I do not think you will want 13 up front with a cub. A lot will depend on where you ride and what transmission set-up you are using... Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 5, 2009 Report Share Posted May 5, 2009 stock is 14/41. no reason you should have trouble pulling 14/42. it will be easier on the motor. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted May 5, 2009 Report Share Posted May 5, 2009 it will be easier on the motor. Yup. Quote Link to comment Share on other sites More sharing options...
FireHead Posted May 5, 2009 Report Share Posted May 5, 2009 stock is 14/41. no reason you should have trouble pulling 14/42. it will be easier on the motor. Keep in mind, that the bigger the chain wheels you use, the longers the chain wheels and chain will last. :thumbsup: Quote Link to comment Share on other sites More sharing options...
2slow350 Posted May 6, 2009 Report Share Posted May 6, 2009 It could depend on alot of things to get the best performance out of your setup.. For example, are you drag racing, your weight, tire size, tranny, etc.. But yea a 14-42 should work. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted May 6, 2009 Report Share Posted May 6, 2009 It could depend on alot of things to get the best performance out of your setup.. For example, are you drag racing, your weight, tire size, tranny, etc.. But yea a 14-42 should work. ther u go, tire size will be a big factor in gearing, as well Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 6, 2009 Report Share Posted May 6, 2009 You have an override in that thing? Reason i asked is i do and i find with 15/41 5th gear isnt fast enough in a drag race. But if i put pro wedges on my bike, it's more than enough. Which is good cuz my n-down 1-5 dunable doesnt have 6th. I gotta be pushing noticeably less power than you so i dont think you'd have trouble pulling that at all. If you do, you have issues imo. What type of riding/racing you will are going to do? Quote Link to comment Share on other sites More sharing options...
steven Posted May 7, 2009 Author Report Share Posted May 7, 2009 im running a stock tranny with no override and running 8 paddle haulers. i only ride in sand. but i dune and race half and half. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 7, 2009 Report Share Posted May 7, 2009 (edited) Ah yes sand. Something i've never ridden in . Nevermind what i said then. Sorry. one day....ill get to ride in sand. Edited May 7, 2009 by RagunCajun Quote Link to comment Share on other sites More sharing options...
