yeah mine i lost 6th. I wasn't aware that a company made a 1-6 dunable. Either way with my gear 15/41, 5th is plenty fast enough. Against the average bike, you should be a head a good bit where it doesnt matter.
Edited by RagunCajun
With the 1-6 duneable you're talking about, you can't still get the nuetral down can you?
the duneable with 1-4, 5+6. Is that the one ive heard that if you dont come to a complete stop before you down shift, it will blow up your bike? how does it blow up your bike, does it shove it back down into first gear or somthing?
So say you get a 2-5 or 1-5 dunable, you lose the 6 gear right? so your overall top speed will be less?
Yes, you will not have a sixth gear.
All you need to do is change your gear ratio to make the 1-5 equivalent to 2-6 on a normal transmission...
