I am putting my first set of paddles on and need a bit of advice. I know that when you put them on that you are supposed to try to get them so the paddles grab evenly. I have adjusted them spline by spline and they are as close as they can be but one is still slightly ahead of the other. Is this going to really affect the ride? Thanks in advance.
if its just a little bit it depends on your pressure and setup, but a little wont hurt slow but can get some speed wobble. I get my hubs even then align one paddle with the valve stem and am good to go
The only time you will really notice it is on hard surface.You will feel it pretty bad going slow.Other than that,I dont think it really makes a shit.I always line mine up though :biggrin:
I have never purposely lined up the paddles and I have never had a problem.
Seems kinda OCD to me to line up the paddles. They turn so fast that I just cant
see where it would make a difference either way.
I get mine close but never went that far outta my way(IE remove hubs) to make them line up.. Have never had any problems.. As they are pretty close Iam sure your good to go..
RIPPEN
