alright i talked to a local builder today and im gonna have him do some engine work for me. im having him port cylinders for my 4mil and and im gonna have him add boost ports right away..he says they add alot of power down low and im debating on whether or not to have him port the cases. he says it will help alot too but i just wanted some input before i spent the extra money. any input would be greatly appreciated!
contact a BansheeHQ approved builder first. then compaire prices. then ask for advice from us again...
what is he charging for the case porting? Its definitly a good idea, but if he is gonna charge you an arm and a leg for it there may be a better route you can take.
WHAT is case porting ?
anyone have a pic of this ?
Its just matching the porting on your cases to your cylinders. Gets rid of the ledges and ridges caused by putting ported cylinders on stock port cases. Only takes a few hours to get pretty decent results with the right tools.
If you go to the images section and search for ported cases you can find some pics of some I did a little while back.
Does a dog and peanut butter qualify as porting tools? :ohmy:
it is going to port my cylinders to match for a 4mil, cut my domes, add boost ports to the cylinders, and do the case porting for $475 bucks. and he said he does use the epoxy when he ports his cases and he uses the best stuff he can and claims its close to $100 for the epoxy. that sounds expensive but he said its the best you can buy and if its gonna be stronger than you cant put a price on reliability. to me that sounds cheap comparing prices with other builders. what do you guys think? and as for the dog and peanut butter..give it a shot lol:)
the best epoxies are quite pricey (like 35-65 for a small tube) but they perform awesome, and are aplication specific. i can see it taking a tube and a half to fill the cases enough to account for the removed material.
i had a set that kevin from hjr did that i loved but to compare them to the same port work without the boost ports i don't know.any good builder could tell you around about how much they help
does $475 for all that work sound reasonable or pricy to you guys? the guy doing it is a buddy of mine so he is doing it all at cost at D&D. their porting is quite expensive to add the boost ports and with the domes and case porting i know he is giving me a good deal but how does that sound when compared to other builders prices?
