Hey everyone I have a 04 banshee stock other than v force reeds toomy t-6 and k&n in box filter the motor is low on compresson still runs so i want to rebuild before it blows. i was thinking about welded crank wiesco pistons and the +4 timing plate and mabey a cool head so i guess was just wondering what brands people would recomend and what u have ran on ur bike thanks alot :cool:
good luck on the rebuild.. btw whats your compression on the cylinders?
i am at 500ft it is -15 out here in canada has 90 psi on one side and 60 on the other
ohh yeah it time for a rebiuld.. if they was both 90lb wouldnt be too bad but the one at 90 and one at 60lb is not good... get it bored out new wiseco pistons,timing plate,nos head with 20 or 21cc domes..
[/quote
thanks for the info how much compression should it have with the 21cc domes
Get the cylinders ported. There is no better time since your rebuilding it. After pipes a port job is the next big increase in power.
If it was my choice between a port job, and a cool head, I would do the port job. You can always slap a head on later.
where about in Canada are you
next steps I'd recommend would be- mild port and if you're on a budget mill the head. if you like the bling and may want to play w/ different compressions-get the cool head.
iam just out side London,Ontario.Nice to know that there is a least one more shee owner in ont
thanks jeff PS ite have my shee for sale,if you know anybody looking
near ottawa ontario
