youd make more out of shearer or cpi inframes. what all is done preformance wise?
fully ported cylinders done properly squish demintions for max power and cooling, machined head and case, 185lbs each side, yamaha race clutch heavy springs, TZ bearing on PTO side of crank, some billet stuff, boost ports, 2T2 rods, trued welded crank, carbon reed/spacers, ported expoyed cages, has 35mm gas carbs on 112 octane. seems to run quicker with smaller alky carbs. walks away from cheetah cubs so far. its 68mm bore 61mm stroke. +2 front gear, 8 inch arm, twist throttle, dual filters.
ur putting that shee threw trails. that thing needs a open field or something. and yah put in frame cpi's on they give u more emmf.
it rides fine on trails, i know how to ride it so it wont foul plugs and overheat. i have woods behind my house i like to make a lap with it, but usually its taken to a rock mining quarry with a half mile uphill run.
cpi's will give u more low/mid..... i loved my cpi's.
i will check into them, i would go outframe but i ride on rather rough terrain and jumps so i wouldn't want to break them.
im wondering do you un-load your tires when you do hit the wheelie bar? with it being that short and only attatched to the swinger it may be doing that to you..
do you mean does it pick up the bike because it locks the tires into the dirt more.
