My local mechanic gave me GearSaver Tranny Fluid 80W....what do you guys usually run for oil? I probably should have asked before I bought anything. :down:
I live in Florida, and the temperature doesn't change much so "winter" thickness oil is not for me.
Thanks fellas.
Thanks fellas.
If I remember correctly I have ran both the 80w and 85w gear saver.. Havn't had a problem at all..
Seems to be pretty good stuff..
RIPPEN
Thanks fellas.
run it! there are shitloads of oil treads.
Good deal, I'll go switch it out today then.
Just tryin to be safe rather than sorry, thanks guys. :biggrin:
I wasn't sure on the weight.
I personally like the gear saver. I have been running it in my suzuki for awhile and never had an issue with it. Its been around forever to. Plus its easy to see if you have a leak cause its bright red
