Building a 421, 4mill cub motor and I just picked up a 1-4 overrride transmission for it. Should i have went with a different trans for my setup. Bike is gong to be strictly for drag racing. any input would help. thanks
I kinda think that if you go with the 1-5 you have a wider range of sprockets, but if you run the same track all the time then a 2-5 will work just fine...In the 1-5 you can start out in 2nd but if it bogs off the line you can change some gearing and start in 1st. Hopefully this makes sense.
1-5 duneable override is the way to go.
If you only, ONLY run 300 foot sand, 2-5 is best, but....if you decide to go to pavement, or the dunes and run a 400, 500 or longer race...you'll need 5 gears....
I run 300ft 98% of the time, but...when I go to the ice, it sure is nice to have 1st gear.
1-4 will work, but for launching hard in 1st gear, it is tough due to how low the ratio is.
I can get you the best deal on the net on override tranny's...
I've had a 1-5 N down dunable in mine for 2 years, flawless....
i have one of his trans he sells and one more on the way. there great
YOu won't like the 1-4. Like Dave said..you have to gear it to launch in 1st so you don't run out of gear, and that just doesn't work very well.
I talked to some people today and they said its more than likely a 1-5 overrider becuase no body really does a 1-4. When i bought it the guy said he was selling it for his friend. I guess i will see when i get it here. Any idea on how to tell what override it is? thanks
I run way longer than 500' races and do pretty good with only a 2-5.
I run a duneable 1-5 neutral down I got from HJR. I generally launch in 1st at the drags and ride it pretty much like a stocker in the dunes. I would highly recommend it for anyone, not just high horsepower machines. They are very durable and shift like an automatic.
