dsmrx7 Posted October 9, 2008 Report Posted October 9, 2008 I need to know if there's an alternative to Yama Bond. Someone suggested 3 bond, but nobody has here on Guam. I know Permatex will not work. Could I use the OEM Toyota Sealant for the Oil Pan? That's all I can find. Thanks Everyone... Quote
BellicoseBanshee Posted October 9, 2008 Report Posted October 9, 2008 I was going to say HondaBond, but if you cannot get Yamabond, you probably will not be able to get it as well. :ermm: If you can find it, HondaBond is better than YamaBond. Quote
Bansh-eman Posted October 9, 2008 Report Posted October 9, 2008 I was going to say HondaBond, but if you cannot get Yamabond, you probably will not be able to get it as well. :ermm: If you can find it, HondaBond is better than YamaBond. its it the same stuff in a differnt tube? Quote
BellicoseBanshee Posted October 9, 2008 Report Posted October 9, 2008 its it the same stuff in a differnt tube? I think the HondaBond is a little thicker, more firm, or whatever you would call it. Quote
dsmrx7 Posted October 9, 2008 Author Report Posted October 9, 2008 What about Toyota 102 Sealant (pt # 00295-00103). It says for Oil Pan/Camshaft housing... Quote
Koolguyson Posted October 9, 2008 Report Posted October 9, 2008 I like 1211. Yamabond/Hondabond (Same stuff) sets up too fast Quote
bansheesickness Posted October 9, 2008 Report Posted October 9, 2008 permatex make some stuff called MOTOSEAL and is gas, oil safe. most autoparts stores have it. Quote
someone82 Posted October 9, 2008 Report Posted October 9, 2008 I used to run motoseal in all my vw motors, but you don't have the internal pressures in those motors as you do in a 2 stroke. So i would say a 50/50 chance on running it. :shrug: If you do use it make sure you let it sit for about 5-10mins before you put the case half's together. I read a post a while back that someone said they used windshield sealent! Quote
jharader Posted October 9, 2008 Report Posted October 9, 2008 Threebond 1211 is what i use as well, good stuff hella expensive though Quote
KEVSWS6 Posted October 9, 2008 Report Posted October 9, 2008 permatex make some stuff called MOTOSEAL and is gas, oil safe. most autoparts stores have it. This stuff works good. I have used it many times. Quote
BenBB Posted October 10, 2008 Report Posted October 10, 2008 This stuff works good. I have used it many times. Same here I've had no problems with it, got it from Napa. Quote
FireHead Posted October 11, 2008 Report Posted October 11, 2008 its it the same stuff in a differnt tube? It used to be, but since Yamabond repackeaged their product, it seems the product change a bit............ I don't know if it's the same anymore. Quote
Snopczynski Posted October 11, 2008 Report Posted October 11, 2008 What are you using it for? Cases, Gaskets, side cover, which one? Quote
yambretta350 Posted August 6, 2009 Report Posted August 6, 2009 What are you using it for? Cases, Gaskets, side cover, which one? What works best for sealing pipes? Quote
