I have been running the barnett for like three seasons now and Im sure it needs to be changed soon. I was looking around at the prices and I cant find them under a hundred bucks.
Im just wondering if anyone has any real world experience running the dirt digger and then another clutch like say the tusk or F.A.S.T.'s clutch.
I would love to only pay the 50 bucks for the tusk if I knew it would last as long.
thanks
you can build a clutch system get you some fzr1000 fibers and steels from a raptor
the tusk clutch seems to hold up for the price.
Ran the Barnett clutch in a different bike and did not like it. Used the Tusk clutch for a couple of years without any trouble, but the F.A.S.T. clutch will be my next. Bottom line, I have heard from quite a few good sources that the F.A.S.T. clutches take a beating and keep on ticking. My $0.02 worth...
What didnt you like about it? I am running the Carbon Fiber Dirt Digger. I have had it a few years with no problems. The only think I dont like about it is it seem to make the transmission oil dirty pretty fast. Even when running Bel Ray Gear Saver.
I have som Silkolen Comp Gear oil in there now and it seems to be staying a nice clear red color now. It says it works with clutches that have Aluminum (steel plates).
I installed one in my R about twelve years ago, and it just didn't feel as nice as the stock Honda clutch. A while later, I installed a new Honda clutch with (I believe) CR500 springs, and it works great. It was just a standard Dirt Digger, and I would be willing to bet the ones manufactured now are much better than the ones made 10-12 years ago. The Barnett did not fail, I just didn't like the feel... :shrug:
I might try the Silkolen Comp oil...
I ran the TUSK for 2 years and it worked flawless. If I had a close to stock motor I would run it again. The only reason I changed to the FAST was because I turned my motor in to a ported 4 mill and thought maybe I would need it. For the money and if your only ported with a few bolt on's Id save the cash and get a tusk again. You can get like 2 for the price of the FAST. Not saying the FAST isnt great because it is I do like it. Just saying you may not need it.
Well.. I run Tusk kits in my drag bike and they hold. I dont use the Tusk springs though.. I use Toomey springs. I alternate between the FZR1000 fibers and Tusk Fibers because I buy the Tusk kit for the steels. So every other year is a full Tusk kit.. lol
The only problem I had with the barnett was that when mine heated up.. it glazed the fibers..
Ok thanks everyone.
I will probably just go with the TUSK then since I am on a budget and have to get ready for the next dune trip.
If it doesnt hold FAST all the way, I figured I would get a FAST over the Barnett since they are the same price.
tanks
