locogato11283
Admin
Everything posted by locogato11283
  1. I'm 5'9. Currently at 185 and dropping.
  2. DDQ is pleased.
  3. We're probably not going to see LED do a full on DM build with pipes any time soon, but there is some stuff in the works that I'll have more info on in a month or so.
  4. Tell him to fuck off. That's a steal for them even without the internals and pads.
  5. That's cheap as fudge.
  6. I've paid $300 and $650 for a set. $300 was a 3 week turn around. $650 was a 4 day turn around.
  7. As long as the site shows it's reserved and you have CC confirmation I wouldn't worry about it. The camp won't be full anyway.
  8. Those people at LSPS are so worthless. I've never had an issue with site booking though. I guess you've tried calling every day?
  9. Gotcha. We will be up top with all the other unruly people.
  10. Yes. It's exactly what you need. There's a huge triple asphalt class.
  11. What pipes are you running now?
  12. You need to e-mail Tim. I doubt he will answer his phone. He is slammed with work. E-mail: [email protected] If you can't get him, there is always Turbo Chassis. I have two of his arms and they are top notch also.
  13. Ally Bolts is a BansheeHQ sponsor.
  14. Call Alba and see what else they offer. They may have stock width arms.
  15. You will not regret the order. They are excellent pipes.
  16. LED is just like every other builder who does excellent work. He's busy and as far as I know only has one or maybe two employees. Arlan is pretty big in the vintage dirt bike scene. As far as I know he's the only person who does custom hand coned pipes for the old 2-stroke dirt bikes.
  17. Pics?
  18. I don't think Arlan has many if any unsatisfied customers. His DM pipes are absolutely the best you can buy at this time, both in quality and performance. The only thing I would tell you is that he is very busy and I'm guessing his lead time is quite a while.
  19. No. The lower mount on the shock won't work.
  20. I would run Snipers. They made more power than Shearer and CPI on every motor we ran them on. We ran them on two 4mm Cubs and a 10mm Serval all built by different builders. The results were the same on all three. Snipers pulled harder, made more power and pulled just as much RPM. Here's the 10mm Serval chart - http://bansheehq.com/forums/index.php?showtopic=171645&page=1 Here's the 4mm Cub chart - http://bansheehq.com/forums/index.php?showtopic=174368&page=1
  21. I'm guessing the build up of oil is from the lack of spark. Have you checked to make sure the flywheel is seated properly and not loose? A loose flywheel will cause all kinds of issues. Once you've determined that the flywheel is not the culprit, then I would move on to the electrical. Have you checked the tabs that hold the coil on? they should be bare metal to help with grounding. Generally the coil is either good or bad, I've never seen an in between. The CDI can however produce intermittent spark.
  22. I have a ton of small t-shirts in stock. I will cut someone a deal on an order of 3 or more! Hit me up!
  23. I would call Noss directly. He will want all of your motor specs to make sure the domes are correct.
