ClaudeMachining
    110
Everything posted by ClaudeMachining
  1. There is a nice write up about ground made by Brandon from Mull Engineering, so it will save me explainations ;+) This is my setup. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  2. Mine is .25 oz ;-) But yes, it's good, with the easy drain plug.
  3. Carl did a good job on my DL cylinders.
  4. Insert other media What will it be?? 46'' ?? My front will have about 48", about 46'' rear should be good.
  5. I have a new idea of a thread. It will be called : Ask the dumb engineer I will answer some questions that i found interesting. If my english was better i would do it in vidéo format which can be funny with my french accent. I already got my first subject: Safety Factor. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  6. Make love, not war. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  7. Same 12`` long, 2`` diameter tubes. One is solid and one is hollow. Same forces on them. The solid weight 1674g and got a max stress of 7070psi. The hollow (.250`` wall) weight 732g.and got a max stress of 11000psi. So no debate, the solid is stronger, the simulation is 100% accurate. The fun part is lets check how big the hollow have to be, to be as strong as the solid and how i twill weight. That is engineering, that is the fun part. I played with some config for about 5 min and here is the results : With a hollow tube of 2.4`` Dia, you got the same strengh with 900g weight!!! That’s why we say solid is always stronger for the same shape and size, but hollow have a better weight to strengh ratio. I hope i twill clear any doubts about this subject. Theory must match real life and i gave you the example. Short story: It take a 2.4`` hollow tube with .250 wall ( 900gr) to be as strong as a solid 2`` tube. (1675gr)
  8. Goats are better
  9. ^^This. Stronger AND heavier. I'll put some formula later, not to brag, just for the sake of the discussion. Engineering is fun and MUST match real life. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  10. Theory and real world always match. It match in this very case too, but for some reasons, that i really dont understand, you can't belive a mechanical engineer with 20 years of experience. I already provided a simulation, Nick explained it , torsion and shear formulas are known for century!! What else can we do??? It's not even debatable ffs!!! It's BASIC ENGINNERING, i can also provide formulas if you want. Then what, you will say those formulas arent true?? Same size/shape , solid is stronger. Same weight, hollow is stronger. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  11. SMH...
  12. You have your answer on those pics. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  13. Yes. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  14. I was just using the search function about JJ&A axle and saw that claim who is not supported by any theorical background. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  15. "
  16. Well, that suck then. He will keep his mouth shut for a while i guess... I missed the fb post, was it on bhq or South fb page?? Envoyé de mon SM-G935W8 en utilisant Tapatalk
  17. He is a sponsor here... And we only got one side of the story. I dont like Nate that munch, but as far as i know, it's the first complain of that type i saw about him.
  18. it's not that munch $$ to ship in Canada...I ship stuff to USA and it cost me less than ship it to Canada...
  19. Exactly. 55$ shipped to your door. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  20. I'm using Snipers small bore inframe, i designed those clamps for it.... I'll try to take a pic tonight.
  21. Those are the best clamp for Snipers pipes, nobody's doing dual diameter but me. That's why they dont leak. Cascades are not dual diameters and are 1.75", mine are 2" long. They fit Snipers, DMC, Shearer, fmf fatty and some others. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  22. He told me: Pwk39mm with cables. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  23. That's what i do 80% of the time and some sand pit. So i told Cam that i do open trail and Sand pit, no tight trail at all. I will send him a link of my vidéo, he will know what kind of riding i do. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  24. Stock frame, by now i play in between 200-210lbs
