driftingbanshee
Everything posted by driftingbanshee
  1. Anyone got a pair of Dunlop radial KT335 they want to sell? 20/10/9 in size would be sweet.
  2. Alba! /thread dont talk to morons you only educate them..
  3. dbro personally if I was building a motor or the likes I'd go LED to spec. yes expensive but will get most out of your motor. splash the cash on building it why not match it with a specific product and not something of the shelf.
  4. Cpi! And if you wanna be a cheap kent then poor man's are like $399 in raw dont talk to morons you only educate them..
  5. Assuming the info here you mean stock carbs? Stock exhaust? Now you have taken the lid off? As stm tpr said adjust screws and you may want to go up a jet size or 2 given you are now feeding more air through the filter and now down the small intake track of the snorkel. dont talk to morons you only educate them..
  6. Most of the time they will run on a 25 with those but through 1 size bigger then adjust your air screws again. Should be gold dont talk to morons you only educate them..
  7. Sounds like slides are in backwards. Cutout (half moon) should be filter side and at the bottom. Won't idle but will run fine after bout half throttle dont talk to morons you only educate them..
  8. Sent you a pm peter dont talk to morons you only educate them..
  9. I've been running mine for a few months now and I kick with my heel without even thinking like it's normal practice these days. Other than that happy as with them. Super strong and a good feel dont talk to morons you only educate them..
  10. I'd say you might be a bit small on the pilot but it varies bike to bike. 320 will be close but maybe a touch on the lean side. dont talk to morons you only educate them..
  11. Haha you guys. K&n you are mostly paying for the name. Paper filters that are marked no brand filter just as good as them given they are a paper mesh. oil and throw an outerwear on them and you save yourself a 80 - 100 bucks. If you are in dust then go to a twin stage foam
  12. Should be around the 330 mark I'd say. Go a 340/30 and plug chop it. I'm on a 310/30 with pipes and no air box at around sea level so I would say you would be at least 2 sizes up on mine dont talk to morons you only educate them..
  13. What type of riding are you doin? dont talk to morons you only educate them..
  14. Looking good man dont talk to morons you only educate them..
  15. I'm on 340s with stock carbs and only bolt ons. dont talk to morons you only educate them..
  16. Park brake been removed? Check the wires for that. Sounds like it's not by passing. Park brake is 2300rpm I think but it will shut down a cylinder. Just a thought dont talk to morons you only educate them..
  17. Looking at the top pic the slides look flat? The opening should be a half moon shape but it's hard to see in the pic. Looks like the could be in backwards dont talk to morons you only educate them..
  18. What mods? dont talk to morons you only educate them..
  19. Is that for the wife or the bike? Glws jd
  20. In for the lols.... dont talk to morons you only educate them..
  21. Got xfr on my bike. Absolutely love them. The heel guard on the kick side is only a small flaw. I just use my heel to kick. Other than that they are faultless dont talk to morons you only educate them..
  22. 27.5 or 30 pilot. I'd say closer to a 27.5 but you will def want to get away from the 25. dont talk to morons you only educate them..
  23. Yeah you can get them in the wrong carb. The notch should be facing the filter side. If it's not the bike will run like a pig until you get to at least half throttle and onto the main jet.
  24. Sounds lean. I'd expect you would need a bigger pilot at least and be up on 290 mains How are.you determining that it is rich on a 270? Have you checked the slides are not in backwards?
  25. 1) What type of aftermarket exhaust do you have? | CPI in frames 2) What type of airfilter do you have? | 2 stage UNI filters 3) Are you running a air box | air box removed 4) What is your elevation? | sea level upto 500 5) What size pilot jets are you using? 30 6) What size main jets are you using? 340 7) What temperature is your Banshee jetted for? | 15 - 30c 8) Do you have a port job? | no 9) What kind of carbs? | stock mikuni >10) What size carbs? | 26mm
