tdod101
Banned
    2
Everything posted by tdod101
  1. Will the FAST billet round house style rear carrier bolt right into the 1997 swing arm ? I know yamaha changed it up a little bit in the 90's
  2. tdod101
    Rear Carrier
    Hey all, looking for a rear carrier that will fit the 1987 swing arm. Call or text Tom at 647 466 1677
  3. Your welcome
  4. That's what he said!
  5. It will be inside diameter
  6. Ok great thanks, I'm gonna use the chain breaker on the old one just to see how it works, if I don't like it ill try your way
  7. Watch JLsparkys video on how to do it, I did it my self as well and it was quite easy
  8. Buddy at the store said that the one link equals one pin, is this correct ?
  9. Yea bought the chain today, they only has 120 so I gotta take out 16 links, bought a chain breaker too
  10. You Americans get all the good shit, best stuff I can find around here is mothers or mcguirers
  11. 190 will lean you out and blow your motor
  12. If you have pipes it's gonna be a bigger main jet, trust me
  13. Some say you need it some say you don't, it's a splash guard, do with it what you please
  14. Going with this: DID 520 ATV X-RING Chain 520x104 Fits: 1987 YAMAHA BANSHEE 350 Part# 1009860010
  15. I've never bought a chain, is that the length ? In what incriminate?
  16. Gonna get a new chain this week, what size do I get ? Stock read end and arm ?
  17. Get a sync tool or watch this video:
  18. Try that jetting
  19. lol! Hilarious! Mix your gas a little richer than normal, ride it like you normally would but don't hold down WOT for more than a second or two, change your oil after every ride, clean your filters after every ride as well. Do this for 4 or 5 rides and your good to go, than change your gas mix to what ever you were usin before. It's not hard, just don't rape it right out of the gate!
  20. If your under a 2500ft elevation. And you use a stock air filter with lid and snorkel, try 240 mains jets, 25 pilot a/f screw out two turns.needle at middle clip, also make sure you have both bowls in the correct carb, there's one with a jet in it that goes on the carb with the choke. Make sure your slides are facing the right direction and also your choke tube is in between both carbs. Start with all that and report back, take pictures as well too
  21. There's part of your problem, what pipes and silencers do you have ? Stock carbs as well ?
  22. What's your jetting ?
  23. Hmm, clean your carbs, I whats your jetting like ? What are your mods ? What kind of fuel ratio are you using, list as much info as you can
