bansheefromhell
Everything posted by bansheefromhell
  1. hybrid drag/dune frame with chrome arms, tie rods and stem, comes with spindles too. has what looks to be stress cracks on the gussets on top of the frame for the steering stem and has a couple if tabs welded on at the last minute for inframes $750 southern Oklahoma
  2. I just wanted to post this, nothing wrong with it just thought its a really cool looking shee for the price http://tulsa.craigslist.org/mcy/3760412755.html
  3. need a good set of stock cylinders ported or not as long as they don't need to be re-sleeved
  4. had this happen before, just drilled the frame and rear holes in pegs to 1/2" and ran a piece of all tread through it and used a couple of nuts to tighten it up
  5. the 04-05 yfz rear caliper is the same it just has a different braket bolted to it
  6. What kind of pistons you gonna use ? I'm going to send them to fast, so whatever they recommend
  7. it's not too bad, I was wanting to rebuild it and this will give me a damn good reason lol. it's a cool head so a new set a domes will fix that right up!
  8. wouldn't that be awesome lol
  9. you can see a piece of a ring lodged in the side of the piston
  10. no signs of detonation but it looks pieces of a ring are stuck in the piston and dome
  11. left cylinder is dead barley even registering on the gauge right is at 150, I'm wondering if I've even should have been running pump fuel in it, I just took the guy's word when I bought it that he said it runs on pump fuel. whelp ill be giving FAST a call!
  12. put the v3s in and still the same, I'm going to have to get a new compression tester I borrowed my dads and it's 30 years old, showing 30lbs on the cylinder that it was running on....
  13. I pulled them out, they look good, I will put the v3's in and see if that fixes it...
  14. ill check that out then, I have a set of v3's so if I have to send one back I won't be out of commission.
  15. it might sound stupid but I kind of hope I need a new topend, I've been wanting to send the cylinders off to FAST and have it freshened up
  16. exhaust, reeds are new v force 4's
  17. http://dallas.craigslist.org/dal/mcy/3789266254.html
  18. What is it with hacking up Banshees to do this stupid shit? yeah it never turns out like they expect, the power to weight ratio sucks and the frames usually look like a suicide wish...
  19. went for a ride Sunday and about 4 hours into the ride I let off the gas and it died. was very hard to get to start, it would rev out but as soon has I let off it died. we towed it back cause I didn't want to do any damage to it, got home cleaned the carbs thoroughly with air and cleaner hoping it was a low side jet stopped up, put it back together did the same damn thing, it also would kick back hard sometimes and backfire, that made me think the the flywheel slipped. I will check that tomorrow, just wondering if this sounds familiar to anyone.
  20. you'd probably think it would look good if it had some fmf pipes on it lol, it's candy apple green fuck stick...
  21. http://tulsa.craigslist.org/mcy/3711440989.html
  22. ill go ahead and try it since it's already on it
