hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. POST PICTURES TRY A DIFFERENT COMPRESSION TESTER WHERE AT IN KANSAS?
  2. Did you ever get your odd compression test results figured out?
  3. I thought you guys had the metric system up there? That must be an American made screwdriver?
  4. Do you know how to tell if your slides are in the correct carbs?
  5. Slide in the wrong carbs? That will make it seem like only running on one side.
  6. yes, your probably wrong there, and yes. STOP running it if you think it has stock jets-- NOTHING good will come from it.
  7. Wow, I didn't mean for you to run it without mufflers, bad idea. Remove and VISUALLY CHECK (look) inside the entire exhaust system. Oh well, probably not your problem anyway.
  8. 120ish, check the pipes for rat nests, squirrel nuts, etc.?
  9. Is there a question in there somewhere? What jets are in it now? When the choke is pulled it IS getting more gas...It is actually a fuel enricher, not choke in the normal sense of an air choke.
  10. Update? Anything new?
  11. If you're trying to get a quad bought from here, you'll need to log on more frequently to keep up. Life moves pretty fast. If you don't stop and look around for a while, you could miss it.
  12. no need for that kit Post your mods and elevation. FMF like a big pilot, they recommend 30 They also recommend a 260 main with the lid on, also a very good starting point.
  13. Go to FMF's website under rider support - jetting, it's all there.
  14. Rat nest in the pipes
  15. Where "in the carbs"? As in also in the engine... do a compression test Also did you get the slides back in the correct carbs?
  16. Or use Facebook to host it for you. Unless you don't have a Facebook acct.
  17. you sure you're running a 14/41? I went to 13front and had to grind the slot forward to shorten my chain to fit.
  18. I guess I missed what are your signs of being lean?
  19. The only thing changed was the plate? Really makes no sense, ya know?
  20. Please participate in my Facebook BHQ poll
  21. Please participate in my FACEBOOK poll
  22. The seals aren't very big at all, barely bigger than the notch they fit in. I'd say the clamp is worn.
  23. Really?, everybody anymore has a OEM parts breakdown list online
