db25
Everything posted by db25
  1. 0000 Steel wool will not scratch it
  2. Steel wool will work miracles on you're pipes
  3. Don't drill them.. They are only like 6 bucks a piece, just spend the money and do it right..
  4. Plug chops.. Best way to see if you're lean..
  5. IPhone sucks balls.. Get a Android and you will be much much happier
  6. Sandfest is in sept. Before the HQ ride
  7. Little Sahara Oklahoma..? You going to sandfest.??
  8. Totally worth the 200.. Buy it
  9. Where is KP dunes at
  10. I'm still interested in the plastic heel guard part if you want to sell those separately
  11. Tors is removed. To start it yes I do give it a little throttle, choke if its sit awhile. The air to fuel screws are two full turns out. I messed with them some while it was running and I just couldn't get it to idle really at all, it might sputter for a couple seconds but that's it then it would die.
  12. What do you plugs look like..? And you mentioned it so I'm asking, are you carbs syned..?
  13. I could use the plastic heel guard pieces if you want to sell them separately
  14. What is your compression
  15. Okay cool.. Yeah my engine it totally stock but giving it a boost would be sweet. Does it just help low end power or will I gain some top end also.
  16. If I put one on do I have to change anything else in order for it to work correctly.. Whats the main benefits of using a adjustable timing plate..?
  17. Been thinking about getting a adjustable timing plate but I don't know anything about them. what's the best brand? What do I have to do to put it on? Do I have to change anything else in order to use it and what do they cost to buy. any info would be great. Thanks
  18. What does a adjustable timing plate cost
  19. Anybody else going to be there. When is the banshee HQ ride..?
  20. db25
    Pipe hangers
    Two bolts on each bracket or one bolt in the center of the bracket..?
  21. db25
    Pipe hangers
    You got any pics of yours drilled and bolted. I was thinking of doing the same thing but didn't know what it would look like.
  22. I sent you a message
  23. You can sync the carbs by pulling the airbox completely out and just doing it by sight until they are exactly the same.
  24. 07 Chevy vortexmax ltz
  25. I'll be there as well. It will be a good time
