LCW
Everything posted by LCW
  1. Your port timings will be way different from what you want to do with .015. If you plan on doing a 4mil have the cylinders ported for that by a sponsor on here. As far as pipes I take it you are trying to build your own? I would get into contact with someone like Shearer or Jim at Passion. They have plenty of pipe experience. I wouldn't recommend a 2 into 1 carb setup with a 4 mil either.
  2. You also need to be running BR"9"ES plugs.
  3. Where you are looking at the plating it is on the flat ring end of the plug. All plugs are plated in nickel or zinc I believe. Anyhow the ground strap is welded to that ring. As you get you fuel mixture right the plating will start to burn off of the end of the plug. Notice in this picture how there is roughly 40% of the plating still on the end of the plug. A safe tune is around 25% left. I shoot for around 5% left for my drag bikes.
  4. That needle is leaner than an E needle. The further towards the end of the alphabet you go, the richer. Start with your power jets wide open, which is the screw is backed all the way out. On alky you aren't looking for the color as you are more looking at the plating on the plug and the strap. The plating will tell you where your fuel is at the strap will tell you about your timing.
  5. I would suggest running possibly an EGN or richer down there. I'm running the EGN at the middle position up here. You do have power jets on those carbs?
  6. I would say ditch those stock carbs and snag up some 35mm PWKS. That's the first thing I do when someone brings a bike to me, whether it is stock porting or not. That serval will love more air.
  7. 20cc domes may be a little much for pump gas at your altitude. Most guys stick around 22cc to 23cc for pump fuel. As for a place to start on jetting 350 mains and 30 pilots with 2 turns on your screws? I'm at 2700 so... Start with fresh plugs and stay fat then jet it down till it cleans up on the top end for main jetting.
  8. I have a bike up here at 2200 feet with nearly the same mods. I has the large K&N single no lid, FMFs, decked head, and some mild porting. It is at 320 mains, 27.5 pilots. It's pretty close to where it should be.
  9. I run my alky bikes a little rich on the pilot circuit, I'm at 2700 and I'm running a .125 main and 55 pilot in my 465 cub.
  10. What altitude are you at?
  11. LCW
    Stellar swingarm
    I want one similar to stellars arched arm that has an s shaped lower tube.
  12. LCW
    Stellar swingarm
    Doesn't have to be stellar. I'll look into some other sponsors.
  13. LCW
    Stellar swingarm
    Is there anyway to get ahold of someone at stellar? I'd also be interested in a used one. Has to be arched.
  14. LCW
    Looking for VF2 reeds
    I may also be interested in the petals for the right price.
  15. LCW
    Looking for whole cages. I'll be sure and give that guy a shout. Thanks, LCW.
  16. I need a couple sets of vforce 2s. Must be in good condition with little movement. Thanks, LCW.
  17. Alright got the a-arms. Still need the shocks and intakes.
  18. If J-madd doesn't take those intakes I will.
  19. Didn't check my other thread. Please delete.
  20. Just received my parts today, everything is as described in his for sale thread. Good communication all around. Thanks, LCW.
  21. How about those pictures?
  22. Got the stator cover, carrier with stay, flywheel, and case saver. Still need: The a-arms Intakes for 40mm carbs A set of front shocks Thanks.
  23. Already picked up an axle and stator. Thanks. Still need: Billet Stator Cover Arms non drag Carrier with brake stay Case saver Flywheel Intakes for 40mm carbs
  24. Know anyone with one of those plastic case savers for sell?
