Surfrjag
    4
Everything posted by Surfrjag
  1. i had good luck with the cage but i also took a dremel tool and opened it up a little bit. it was for a blaster.. before and after
  2. also check your reeds out they are directly related to engine responce
  3. its pretty straight forward as a regular transmission just has some springs on the shaft with 2 forks. the larger spring goes between the forks
  4. you can do just the transmission and you can find them for just over 100 usually. what happened to yours? your cases are still good i assume?
  5. she said your 4mil was a 4mil and her cub couldnt feel it.. didnt make it to the serval
  6. cub and serval are aftermarket cylinders. 4mil is a aftermarket crank with a 4mm longer stroke. coup told me so
  7. yes worst but typically a 1-5 is still able to back load in 5th, just not the other gears.
  8. for the price ill just buy a lockup cover or keep removing the current cover when i need a clutch
  9. you could just wire wheel them or sand them by hand and then spray paint them like you said. be sure and use a high temp paint.
  10. thats one bad to the bone bus right there! and starwriter.. thats one bad dude in your avatar pic!!
  11. or it could be that your carbs arent synced at idle very well...
  12. hell yeah that thing sounds good!!
  13. stupid coolhead orings
    1. Show previous comments  3 more
    2. Surfrjag
      Surfrjag
      split the ring on the dome when i installed it. no spares...
    3. 252wheelieking
      252wheelieking
      I use grease to hold mines in place
    4. 252wheelieking
      252wheelieking
  14. what wax and topcoat are you talkin about? sounds like a good trick!!
  15. sounds good to me infamous!! are you serious hellatioius?? go down there and check it out. you will be addicted!!
  16. ill take that pingel with the tires on the other post. pm sent
  17. i have one 20 shipped
  18. i agree 252... im ready to go now
  19. riding the dunes would be sweet!! we will talk about going to LS at the busco ride on june 2nd weekend.. who else is interested in going to busco?
  20. could be a bad oring.. i had a mildly blown headgasket and did about the same thing. it seemed like it would only leak when i was heavy on the throttle.
  21. now thats a nice ride!!!
  22. check that cable isnt pulling slides open. then check for the air leaks or lean pilots edit: always check for airleaks....
  23. what kind of riding do you do?
  24. welcome to the hq! lots of info here just gotta figure out what you wanna do with the banshee and have a goal set for it. dont worry about getting that boost bottle they are junk. think about getting it ported though and that thing will rip your arms off
  25. oil seal or oil getting past the keyway maybe
