possum
    6
Everything posted by possum
  1. Cool sounds good. And you can judge me its ok, Im used to it. Also, Ive fabricated a couple times. If you have a question, my door is always open.
  2. Ive. Been known to get down, unless your a hater, then I suck.
  3. Cool deal!
  4. Here we go!
  5. A lil over kill but strong none the less. You should of beveled the entire face around the nut to fill it then grind flush, instead of the 2 spots. And with those small plug holes, did the weld reach the coupling completly?
  6. I want these, but dont need them either
  7. Stay with stock cyls
  8. Stay at 22
  9. Lmao, I chuckled for a while on this one.
  10. Just go hjr "ultra extreme superfantabulous hardcore port" you wont regret it.
  11. I make my own that bolts under the front seat loop. Its directly above the stator wires. And completly out of the way and cant see it whatsoever.
  12. Hjr
  13. I know I hate that. Please get a tape measure out and use it
  14. Pretty cool hood, someone should pick this up. Alot better looking then most crap I see. Bump
  15. Everybody knows a coolhead cools your motor 20 degrees. So its a must after porting. Cause that causes more heat. Duh..
  16. I spray WD all in the bearings and blow it out over and over till I feel its clean. Then pour some mix in the bearings and reload it with oil.
  17. Fast or redline dont know how to port. They all send there cyls to other builders. They are the middle man
  18. Oem or k&s. Ive had issues with winderosa on the crank
  19. Hjr
  20. Driveline domes work very well
  21. You can change dumps in keihins. Ive done it.
  22. Your**
  23. Yup 4, get them from fast
  24. Any part numbers or series?
  25. If you had jetting issues and they ran terrible. Prob hjr
